diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Swap Meet (http://www.diyaudio.com/forums/swap-meet/)
-   -   Lots of drivers Seas, Vifa , MCM (http://www.diyaudio.com/forums/swap-meet/138160-lots-drivers-seas-vifa-mcm.html)
johnmark 8th February 2009 05:13 AM
Trying to thin out collection,
1 pair of Seas L21RN4X/P were in a den system that was hardly used. Drivers are perfect other than black mounting goop on the back of the frames. $100
1 pair Audax PR240Z0 woofers unused $100
http://www.hautparleur.fr/_audax/pr240z0.pdf
1 pair used Audio Concepts DV12 subwoofers $40
1 pair 15" subwoofers from Parts Express unused, $50
might make a cheap OB woofer. These were from a manufacturer closeout
"The subwoofer features a talc filled poly cone with a treated foam surround. It features a 2" 4ohm kapton VC. The motor structure is vented for increased heat dissipation and has a bumped back plate for longer voice coil excursion. The perfect driver for your next home theater subwoofer project! "
power handling 80 watts rms 115 peak
VC ind 2.07mH
DC res 3.46
freq 33-400
fs 26.6
vas 10.18 cf
SPL 96 / 2.83v/ 1M
qms 11.08
qes .41
qts .40
I also have 4 MCM 55-2185 8" aluminum cone woofers.
They are 2x8 ohms voice coils I see Zaph had run frequency response in his Blog, could make good MTM
How about $20 per pr
16 Vifa AP13FG21-04 full range drivers. $150 for all ?
Bought these to make a line array but lost interest. Un-used.
They have a nice response, vented and copper plated pole piece.
Specifications: * Power handling: 70 watts RMS/100 watts max * Voice coil diameter: 1" * Voice coil inductance: .51mH * Impedance: 4 ohms * DC resistance: 2.92 ohms * Frequency response: 65-12,000 Hz * Magnet weight: 14.6 oz. Fs: 91.7 Hz * SPL: 92 dB 2.83V/1m * Vas: .14 cu. ft. * Qms: 3.12 * Qes: .80 * Qts: .637 * Xmax: 4.5mm * Net weight: 1-1/2 lbs. * Dimensions: Overall Diameter: 5-1/8 ", Cutout Diameter: 4-7/16 ", Mounting Depth: 2-3/8 ", Magnet Diameter: 2-7/8
Postage is from zip 98118
Paypal preferred
John Mark
dtm1962 6th January 2010 12:52 PM
Seas Aluminum Woofers
I may be interested in the 8" Aluminum woofers.
Are they still available?
Resources saved on this page: MySQL 18.75%
