Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 27th January 2009, 12:19 AM   #1
Default FS LM3886 Triple monoblock amp
Hi all,
I need to liquidate some of my stereo gear and need to sell my DIY LM3886 triple monoblock amp. All amp chips and transformers are in one enclosure. The enclosure is a prebuilt unit with a custom 1/8th inch solid aluminum faceplate. The power switch is on the front left and one blue LED to indicate power in the middle. The transformers are Avel-Lindberg and were purchased from Apex jr. The specs are:
Input: 2 X 120Vac 50-60 Hz
3 3/4" Dia X 1 1/2" Tall
Output: 2 X 28.4V @ 2.67Amps over 150Va
All three transformers have their own PS boards as well as 2amp slow blow fuses. The PS boards and the amp boards were purchased from Brian GT at chipamp.com. I originally purchased a dual monoblock kit and then a friend gave me a single monoblock kit he had kickin'around so I thought I would use all three in one enclosure. Each LM3886 amp chip is cooled by a solid aluminum Pentium 4 cpu cooler. I have found that it works quite well. Speaker connections are dual binding posts red and black. I have also used 1\8th inch steel plate to sectioned off each amp from each other and to keep the PS board and transformer isolated from the amp chips. The top cover of the enclosure has slotted vents near the back to dissipate any heat. Rubber grommets are used where wires are feed through. This triple monoblock LM3886 produces 68w per channel into 8ohms. This amp can produce very loud volumes quite easy. I've never had an issue getting any kind of volume from this amp. Now I've never owned any high end amps before, but compared to the amps that come with AV receivers these days, this amp kicks butt!! All you need to do is go to the chipamps section and read the postings. I would really like to get back what I put into it. I'm not looking to make any prophet. This amp really needs a good home.
$300.00cdn OBO plus shipping.
Thanks for looking,
Chevy
Old 27th January 2009, 03:51 AM   #2
Here's a pic of the inside.
Old 27th January 2009, 03:52 AM   #3
And one of the back.
Old 3rd February 2009, 01:01 PM   #4
still have that amp for sale I live in Ontario and would like to buy it how much does it weigh for shipping
Old 3rd February 2009, 08:33 PM   #5
Yes the amp is still FS. The amp weighs about 25lbs boxed up. Give me your postal code and I can calculate a shipping rate for you.
Chevy
Old 3rd February 2009, 09:44 PM   #6
Hey chevy
334 collingwood st
Sarnia,Ontario
N7T 6N4
Old 4th February 2009, 12:05 AM   #7
Shipping to N7T 6N4
Shipping will be $31.00cdn. If you want to continue the conversation feel free to email me directly.
Thanks,
Chevy
Old 8th February 2009, 06:08 PM   #8
Amp is still FS.
Chevy
Triple EF BJT power stage. roender Solid State 14 28th January 2007 10:09 AM
Peavey Triple X Rewire! Help! xtjdx Tubes / Valves 1 28th July 2005 01:47 AM
My monoblock Gainclone LM3886 (photos link) steeve Chip Amps 7 11th March 2005 08:37 PM
The Triple Twisted Snake Blue_Max Everything Else 0 27th October 2004 08:37 AM
Switches - Dual Triple Pole, Triple Throw jackinnj Swap Meet 0 27th January 2003 07:18 PM
Page generated in 0.09222 seconds (76.40% PHP - 23.60% MySQL) with 11 queries
