diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Swap Meet (http://www.diyaudio.com/forums/swap-meet/)
-   -   FS: Adire Extremis woofers and Seas DXT Tweeters (http://www.diyaudio.com/forums/swap-meet/136894-fs-adire-extremis-woofers-seas-dxt-tweeters.html)
Tenson 19th January 2009 04:28 PM
I have for sale a pair of Adire Audio Extremis 6.4 woofers and a pair of Seas 27TBCD-DXT tweeters (the ones with the diffraction waveguide). I have the original boxes for them too so well packed.
Info can be found for them both on www.zaphaudio.com
They are both some of the lowest distortion drivers in their class. The tweeters have well controlled directivity due to the Seas designed waveguide. The woofers have probably the largest linear xmax of any 7" woofer, and low disto.
They would go together to make an incredible 2 way speaker. I just don't have the time or the need!
The Extremis used to cost about 150 a pair, and the tweeters are about 50 each to get hold of in the UK.
I'd like 100 for the lot + P&P which will likely be about 20.
http://img515.imageshack.us/img515/7550/spkrskm3.jpg
Tenson 23rd January 2009 12:24 PM
I will copy a reply I made to someone on PFM here as it may be of interest.
There is no design, but there are driver measurements.
http://www.zaphaudio.com/6.5test/
http://www.zaphaudio.com/tweetermishmash/
There are however some designs using differnt tweeters like this
http://www.rjbaudio.com/Extremis/extremis.html
http://www.humblehomemadehifi.com/Extremon.html
This is quite fun, too! http://uk.youtube.com/watch?v=be2k3pYQIfE
Funnily enough I have a pair of the other tweeters used in both those projects! I'll happily sell you a pair of either of those instead of the waveguide ones here. They are all spare to me. They are all some of the best dome tweeters around (I wouldn't have bought them otherwise). Take your pick.
Copyright 1999-2017 diyAudio
