Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 16th December 2008, 12:14 AM   #1
Default Pair of 15" woofers from Parts Express
Unused
Might work for a cheap OB woofer
Talc filled poly cone
Vented and bumped back plate
4 ohm
FS 26.6
Qts .40
QMS 11.08
SPL 96
freq 33-400 suggested
PE part 299-095
$30 pr !!
Old 16th December 2008, 03:44 PM   #2
badman is offline badman  United States
Custom Title
badman's Avatar
Want to tell us the brand? PE doesn't find that PN on their search.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 16th December 2008, 08:51 PM   #3
I will look at the woofer when I get home but I do not recall seeing a manufacturer name on the woofer just the PE part number.
I bought these about 4 years ago. They must have been a close out.
Old 16th December 2008, 10:14 PM   #4
Custom Title
badman's Avatar
Pictures would also be useful. I'd definitely be interested, depending upon the details, if it appears to be a reliable manufacture. Low(is) Fs and High (ish) Qts and high efficiency, rare balance. I'd expect Vas on the order of 400L if these specs hold (and they're 8ohm). On the other hand, depending on the looks of things, it could be an issue of car audio specifications
Old 16th December 2008, 11:13 PM   #5
Speakerholic
Cal Weldon's Avatar
I tried the number sequence with a 290 instead of 299 and switched some others around and there were lots of speakers but I guess the number has been reassigned. It seems it was last used for a Pioneer 10" poly cone (I think)
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 17th December 2008, 04:14 PM   #6
more info I found the ad flyer so ..
"The subwoofer features a talc filled poly cone with a treated foam surround. It features a 2" 4ohm kapton VC. The motor structure is vented for increased heat dissipation and has a bumped back plate for longer voice coil excursion. The perfect driver for your next home theater subwoofer project! "
power handling 80 watts rms 115 peak
VC ind 2.07mH
DC res 3.46
freq 33-400
fs 26.6
vas 10.18 cf
SPL 96 / 2.83v/ 1M
qms 11.08
qes .41
qts .40
Old 29th December 2008, 03:29 PM   #7
No interest at $30 for the pair ??
FS or trade 1 pair Dynavox 6.5" woofers, 1 pair of Tweets.. JCoffey Swap Meet 4 20th September 2006 04:56 PM
quantity of 4 parts express #295-330 woofers FS noisenyc Swap Meet 4 9th June 2006 12:00 AM
Big discount on 15" parts express woofer bigwill Subwoofers 3 11th May 2005 01:24 AM
Did Parts Express "eat the worm? Da5id4Vz The Lounge 1 14th August 2003 06:50 PM
Page generated in 0.09064 seconds (77.14% PHP - 22.86% MySQL) with 10 queries
