| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
No more time to experiment, need to clean out the parts collection, my loss is your gain.
The following are in good working order unless otherwise noted. Reference picture links are provided. Reasonable offers accepted. I prefer to ship USPS because I don't want to give my money to UPS. Zip code 84093. Vintage gear Compression drivers Emilar $20 Emilar EA175 16ohm good diaphragm but shifted phase plug $30 Emilar EA175 8ohm alnico $30 Emilar ECH175 8ohm ferrite Driver in lower right is EA175 http://www.kozystudio.com/bu2bu2/driver/emilar.jpg JBL $180 for pair JBL LE85's with rare consecutive serial numbers 1 has original 16ohm aluminum diaphragm 1 has newer 8ohm titanium diaphragm http://www009.upp.so-net.ne.jp/kanky...L.LE85.300.jpg Horns $50 2x Emilar EH820 2" throat horns, these have been used in Augspurger monitors http://www.kozystudio.com/bu2bu2/horn/eh820.jpg $140 JBL 800hz H92 conical horns for L300 or 4333 http://www.sound-pit.jp/used7/jbl-h92.jpg Crossovers $120 2x JBL N8000 8000Hz crossover for 077 supertweeters http://www.audioheritage.org/vbullet...1&d=1109794122 New Gear Compression drivers $440 2x BMS 4590P 2" throat coaxial compression drivers with crossovers, never used outside home, now over $350 each new http://lsv-achenbach.de/shop/images/bms_4590p.jpg $170 2x DDS CFD2-90X 2" 90x40 large format fiberglass horns, made in Seattle http://www.usspeaker.com/images/dds-...ro-size178.gif |
#2 |
Tough to contact you if you are not receiving emails. I'll definitely take those EH820 horns.
Dang.
"Audio is filled with dangerous amateurs."--Tim de Paravicini |
#3 |
Hi dogbert,
I'd like to buy the H92 Conicals, do you by any chance have the tea strainers as well ? I'd also like to buy the LE85's if they are still available. Cheers, Peter. |
#4 |
dibs on the dds horns! kekoach(at)gmail.com
#5 |
New & Vintage compression drivers, horns, JBL, Emilar, BMS Post #1
No more time to experiment, need to clean out the parts collection, my loss is your gain. The following are in good working order unless otherwise noted. Reference picture links are provided. Reasonable offers accepted. I prefer to ship USPS because I don't want to give my money to UPS. Zip code 84093. Vintage gear Compression drivers Emilar $20 Emilar EA175 16ohm good diaphragm but shifted phase plug $30 Emilar EA175 8ohm alnico $30 Emilar ECH175 8ohm ferrite Driver in lower right is EA175 http://www.kozystudio.com/bu2bu2/driver/emilar.jpg JBL $180 for pair JBL LE85's with rare consecutive serial numbers 1 has original 16ohm aluminum diaphragm 1 has newer 8ohm titanium diaphragm http://www009.upp.so-net.ne.jp/kank...BL.LE85.300.jpg Horns $50 2x Emilar EH820 2" throat horns, these have been used in Augspurger monitors http://www.kozystudio.com/bu2bu2/horn/eh820.jpg $140 JBL 800hz H92 conical horns for L300 or 4333 http://www.sound-pit.jp/used7/jbl-h92.jpg Crossovers $120 2x JBL N8000 8000Hz crossover for 077 supertweeters http://www.audioheritage.org/vbulle...=1&d=1109794122 New Gear Compression drivers $440 2x BMS 4590P 2" throat coaxial compression drivers with crossovers, never used outside home, now over $350 each new http://lsv-achenbach.de/shop/images/bms_4590p.jpg |
#6 |
I am interested in the BMS driver, please get in touch with me at
dkalsiATgmailDOTcom |
#7 |
Speakerholic
dskalsi,
You are now free to email. |
#8 |
I need a16 ohm diaphragm for my EA 175-16A if you still have that stuff.
#9 |
as per terrykvan
I am after ea 175-16 diaphragm if still available |
| Compression drivers in horns or waveguides | 454Casull | Multi-Way | 6 | 1st December 2008 12:41 PM |
| FS: JBL and Emilar xover and compression drivers | dogbert | Swap Meet | 2 | 4th May 2008 04:38 PM |
| Compression Drivers without Horns? | NV&H | Multi-Way | 17 | 15th August 2007 06:03 PM |
| WANTED: Horns & Compression Drivers | Carl_Huff | Swap Meet | 5 | 14th May 2007 07:43 PM |
| Page generated in 0.12500 seconds (79.77% PHP - 20.23% MySQL) with 10 queries |
