These are used and I removed the shielding and bucking magnet on them to make them less deep due to some mounting restrictions. They were used in my car, but DO NOT have any water/moisture damage. I have taken many pictures of them but if you need more detail please let me know and I can provide it.
Asking $275 shipped OBO to CONUS. They are also listed on ebay right now but I will cancel the auction if bought through here.
Specs
18S/8531G 8ohm
TECHNICAL DATA:
Sensitivity 2.83V/1M 86.5dB
Free air resonance Fs 28 Hz
DC resistance 5.8 ohm
V.C. inductance 0.35 mH
Power 70W
Effective cone area 150 cm2
V.C. diameter 38 mm
VC height -
Air gap -
Lin. & max. excursion ±6.5 / ±11 mm
Air gap flux density -
Force factor BL Product 6.4 Tm
Moving mass incl. air 17.5 g
Net weight 1.75 kg
Vas 59 ltrs
Qms 5.1
Qes 0.44
Qts 0.40
18S/8531G 8ohm
TECHNICAL DATA:
Power 70W
V.C. diameter 38 mm
VC height -
Air gap -
Net weight 1.75 kg
Vas 59 ltrs
Qms 5.1
Qes 0.44
Qts 0.40
