No time to finish this up, things are getting busy again. All components mounted cleanly, diodes were mounted above the board for optimal air flow. The heat sink is actually in two pieces, in the picture you can see where the fin spacing is slightly wider. You don't have to use the smaller piece, but if you would like to you could. You will still need to buy a few components to finish this up, mainly just the capacitors and output transistors. Great opportunity to get jump started on a great amp for cheap. Pictures:
Ill take it for 50. Contact me at steve.gagnon@gmail.com. I can pay via paypal.
