Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Wanted: 8 inch DVC Woofer pair
Old 23rd September 2008, 02:48 AM   #1
MCPete is offline MCPete  United States
Default Wanted: 8 inch DVC Woofer pair
This pair of identical woofers should include a spec sheet or specs should be available somewhere on the web.
Absolutely, they must have DUAL VOICE COILS!
Diameter can be no larger than 8 inch. I'd prefer 8 inch, but might consider somewhat smaller.
Specs need to fit in the following range:
0.2 < Qts < 0.3, Qts with voice coils connected in parallel
fs < 31 Hz
upper limit of frequency response = 2 kHz
The newer the better, of course, but I'll take something older if still in good condition.
Seems as if I'm about 10 years late in looking for a woofer like this. I'm not dreaming that this type of woofer has been manufactured? Oh, well.
Anyone living in the 48 United States (or possibly Canada) who has a pair of woofers like this that they are willing to part with, please write pronto!
-Pete
Old 24th September 2008, 07:26 AM   #2
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
No longer in catalogue but 3 avaliable on Ebay Australia
http://cgi.ebay.com.au/AUDIOPIPE-8-3...QQcmdZViewItem
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 24th September 2008, 07:37 PM   #3
Stuart Easson is offline Stuart Easson  United Kingdom
Stuart Easson's Avatar
Wanted: 8 inch DVC Woofer pair Send a message via MSN to Stuart Easson Send a message via Yahoo to Stuart Easson
Default an option
Car woofers and subs are often available with dual VC:
http://www.partsexpress.com/webpage....ctGroup_ID=846
I did not check the specs (other than DVC), but a couple of these might work for your needs.
HTH
Stuart
Old 24th September 2008, 10:53 PM   #4
Thanks to Moondog55 and Stuart for the advice.
Unfortunately Qts for the Audio Pipe 8 inch DVC subwoofer isn't given. Also power handling of 300W is much greater than I need- I plan to build a system for home listening.
All of the DVC woofers at Parts Express have Qts (with voice coils connected in parallel) equal to 0.4 or greater. Correct me if I'm wrong, but I believe that woofers for car audio generally won't have a Qts of about 0.25.
The closest current woofer matching what I need that I found is 10 inch diameter. This is a Pioneer DVC woofer at MCM Electronics. In the back of my mind also is the thought that drivers by Pioneer are for the most part not highly regarded.
-Pete
Old 26th September 2008, 03:22 AM   #5
bichi is offline bichi  United States
bichi's Avatar
User "IMStoopid" had used Peerless 831858, poly, 8inch, dual 8+8ohm VC, for sale a bit ago.
Total Qts listed as 0.39. I bought two of the four available.
Listing:
http://www.diyaudio.com/forums/showt...hreadid=119112
Specs PDF:
http://www.madisound.com/catalog/PDF/831858.pdf
Madisound Newsletter Sale listing:
http://www.madisound.com/newsletters...-18S_8531G.php
Edit: ahhh, I see you have already asked at "IMStoopid's" listing...
Old 9th October 2008, 02:35 AM   #6
Default Peerless 831858
This past monday I received a pair of the woofers from IMSTOOPID. These woofers are great! I wonder why Peerless discontinued making it.
If anyone has some unused woofers very similar to this Peerless 831858, I could probably use a few more pairs.
-Pete
Wanted: 8 inch DVC Woofer pairHide this!Advertise here!
Best 15 inch Woofer around 500rms?!?! WhiteBoyChriss Multi-Way 22 19th November 2015 10:37 PM
Vifa 8 inch woofer MTruslow Multi-Way 1 8th January 2009 02:24 AM
four inch woofer enclouser? dallaire Multi-Way 15 20th December 2007 11:07 PM
15 Inch/38cm PA (sub)woofer tubee Subwoofers 10 23rd June 2006 09:56 AM
Copyright ©1999-2017 diyAudio
