Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 13th September 2008, 06:42 PM   #1
Audio Junkie
Zero Cool's Avatar
Default Crown PS-400 Needs Work best Offer
Crown PS-400 amp. blows fuses. most likely blown outputs. Someone has replaced the input pots it looks like. missing knobs but in pretty good cosmetic shape overall.
I can repair this if there is interest in it. Willing to sell it as-is or after it has been repaired.
No idea what this is worth. I have way to many projects. if this is worth something please let me know.
Zc
tetech2@doitnow.com
Old 18th September 2008, 01:55 PM   #2
Audio Junkie
Zero Cool's Avatar
Bump,
Last chance before i scrap it!!
Old 18th September 2008, 02:38 PM   #3
d to the g's Avatar
Zc,
I could at least put the power supply to good use!
D
Old 18th September 2008, 03:11 PM   #4
Audio Junkie
Zero Cool's Avatar
you should come by my shop anyway. I have a BUNCH of stuff that could be put to use. I need to make a list and post it here one day. I know i have amp chassis, toroids, heatsinks, parts and pieces of every sort that really could use new homes.
Shoot me an offer on the 400
Zc
Old 18th September 2008, 05:39 PM   #5
Send a message via AIM to Spasticteapot
I need a power transformer between 55 and 70 volts, center-tapped. Any chance you've got one for sale?
Old 18th September 2008, 05:54 PM   #6
Audio Junkie
Zero Cool's Avatar
I probably do. I'm pretty sure i do in fact. I have several power supplies and what not that have some decent sized toroids in them and i have a NICE pair of 600va toroids that are i think 55-0 55-0 windings. i need to measure them again.
I also have a stack of TOA power amp/mixers that have transformers in them but they are EI cores. I also have a stack of Crowns and Crest amps too all needing work. I have a couple of Carver 1.5's and some EQ's and mixers and racks of stuff. anyone local is welcome to come and check it all out.
Zc
Old 19th September 2008, 04:15 PM   #7
d to the g's Avatar
Zc,
The PS400 runs at +/- 62V. Too high for anything I need. But the 1kVA rating is pretty sweet, so are the internal heat sinks.
I'll definitely swing by though.
D
Old 19th September 2008, 05:27 PM   #8
pjanda1 is offline pjanda1  United States
pjanda1's Avatar
Zc, when you say chassis of every sort, might that include potential tube amp chassis? I'm thinking the 15x9" I've got for my current project might be a bit small. If you've got something like an old rack enclosure with a top (or unmolested bottom) that can hold a bunch of weight, let me know.
pj
Old 19th September 2008, 08:12 PM   #9
Audio Junkie
Zero Cool's Avatar
I have a bunch of rack enclosures! I have a nice Crest CA4 chassis 2RU high and about as deep as it is wide. that has nice THICK chassis. I also have the huge toroid from that. I think the rails were +/-85vdc and im sure its a 1kva toroid. but if you just wanted the chassis we can work that out.
I have a bunch of Toa PA type amps that we could strip down. I think i have some new 2ru project chassis but they are pretty light duty and i might have some new 2ru chassis with clean fronts and tops. I have so much crap I cant even get to it all.
I also have a bunch of transformers. Some toroid some EI core. some still in amps. I know i have a pair of giant EI's from a crest amp in a box i haven't even opened. since they were shipped to me. Im quite sure we can find a transformer to suit your needs.
I need a pair or four 250Vac transformers at least 40-100ma something like that if somebody had something and wanted to trade.
Zc
Old 19th September 2008, 10:24 PM   #10
I could really use some whopping big power transformers - EI core, toroid, whatever.
The two I'm really looking for are:
30-0-30 at 5A (or close enough - a hair more voltage should be okay, and more current is always nice!)
35-0-35 at 8A (once again, more current = better.)
Rackmount enclosures are always fun, too.
In return, I have:
http://spastech.blogspot.com/
www.epecpcb.com $500 free PCB offer DCPreamp Parts 11 16th August 2010 06:35 PM
Crown Com-Tech 210 Power Amplifier Crown Com-Tech 210 tyler477 Solid State 1 31st October 2008 04:24 AM
Polk SDA 2B FS make offer 00600 Swap Meet 0 15th September 2007 01:40 AM
job offer: pcb-layout TobWen Swap Meet 19 10th January 2005 11:53 PM
300 VA toroids on offer! Andypairo Swap Meet 1 23rd October 2003 07:16 AM
Page generated in 0.10664 seconds (71.15% PHP - 28.85% MySQL) with 10 queries
