Crown PS-400 Needs Work best Offer
Crown PS-400 amp. blows fuses. most likely blown outputs. Someone has replaced the input pots it looks like. missing knobs but in pretty good cosmetic shape overall.
I can repair this if there is interest in it. Willing to sell it as-is or after it has been repaired.
No idea what this is worth. I have way to many projects. if this is worth something please let me know.
Zc
tetech2@doitnow.com
you should come by my shop anyway. I have a BUNCH of stuff that could be put to use. I need to make a list and post it here one day. I know i have amp chassis, toroids, heatsinks, parts and pieces of every sort that really could use new homes.
Shoot me an offer on the 400
Zc
I probably do. I'm pretty sure i do in fact. I have several power supplies and what not that have some decent sized toroids in them and i have a NICE pair of 600va toroids that are i think 55-0 55-0 windings. i need to measure them again.
I also have a stack of TOA power amp/mixers that have transformers in them but they are EI cores. I also have a stack of Crowns and Crest amps too all needing work. I have a couple of Carver 1.5's and some EQ's and mixers and racks of stuff. anyone local is welcome to come and check it all out.
Zc
I have a bunch of rack enclosures! I have a nice Crest CA4 chassis 2RU high and about as deep as it is wide. that has nice THICK chassis. I also have the huge toroid from that. I think the rails were +/-85vdc and im sure its a 1kva toroid. but if you just wanted the chassis we can work that out.
I have a bunch of Toa PA type amps that we could strip down. I think i have some new 2ru project chassis but they are pretty light duty and i might have some new 2ru chassis with clean fronts and tops. I have so much crap I cant even get to it all.
I also have a bunch of transformers. Some toroid some EI core. some still in amps. I know i have a pair of giant EI's from a crest amp in a box i haven't even opened. since they were shipped to me. Im quite sure we can find a transformer to suit your needs.
I need a pair or four 250Vac transformers at least 40-100ma something like that if somebody had something and wanted to trade.
Zc
