| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
This chassis and transformer are suitable for an amp such as a Hafler DH-220. The toroid transformer will drive a 115 watts per channel stereo amp with supply rail voltages of ±65 VDC.
The diode bridge and cap mounting rings are included. The chassis dimensions are 5.25" tall, 12" wide and 10" front to back. The face plate is the standard 19" wide for rack mounting and includes an ON/OFF switch. You can see cut outs on each side. It used to have Hafler style heatsinks but you could easily mount your own. The chassis has a nice fitted lid with ventilation holes. The back side has terminal strips for inputs and outputs. The back panel also has 3 fuse blocks for AC in and speaker outs. A level control for each channel is also mounted on the rear panel. Price is $35 plus shipping for 20 pounds to continental USA only. I will box carefully and ship via FEDEX. PayPal is preferred. |
#2 |
Here is a different view of the chassis -- with the top removed.
You can see the mounting rings for the PS caps. Note the nice PCB which attaches to the tops of the PS caps and has fuse blocks for the ±65VDC to each channel. You can see the cutouts on each side where driver boards can attach to your choice of heatsinks. |
#3 |
Here is a rear view of the chassis that shows fuses for speaker protection, level controls, and screw terminals for signal input and speaker output.
The electrolytic caps on top of the chassis just happened to be there when the picture was taken. They are each 6600 uF 60 WVDC and are free if you want them. |
#4 |
Woops, forgot to tell you I am at ZIP 61111 in Northern Illinois.
Here is the link for FEDEX so you can calculate shipping for 20 pounds from me to you: http://www.fedex.com/ratefinder/home?cc=US&language=en I pack carefully. |
#5 |
How about $25 plus $15 flat rate shipping cost -- via FEDEX.
The case includes diode bridge and transformer all wired. Just add PS caps and hook up your circuit cards. Case can accept several different sizes of heatsinks. |
#6 |
So $40 to California works for you? email me .....
brutepuppy <at> yahoo <dot> net Send me you PayPal ID via email. I sent you an email already.
#7 |
brutepuppy,
You have email with PayPal ID, etc. I'll ship upon receipt of confirmed payment. Do you want those 60 VDC caps? Or, how about a pair of Sangamos 75WVDC 10K uF 2" X 4"? No charge for the caps. Thanks, Dick |
#8 |
For clarification the transformer is center tapped 45 - 0 - 45 VAC. Therefore, after rectification it can supply the ±65VDC as listed above.
I estimate the transformer to be rated at 450 VA. Thanks for looking. Dick |
#9 |
You got $$
"I speak Spanish to God, Italian to Women, French to Men, and German to my Horse" - Charles V |
#10 |
John,
Will ship on Tuesday. Too many appointments tomorrow. Thanks a lot. Wow, did you see the Americans win the free style relay? Exciting! Dick |
| Music Angel Empty shells | wallagh | Tubes / Valves | 3 | 19th September 2008 07:52 AM |
| need suggestion for sound in empty room | space2000 | Solid State | 0 | 26th May 2008 04:09 AM |
| Empty Chassis with Toroid Trans | Dick West | Swap Meet | 3 | 28th March 2007 03:03 PM |
| Toroid Trans for Hafler and Others | Dick West | Swap Meet | 1 | 27th March 2007 08:51 PM |
| WTD: Toroid Trans | stebbie | Swap Meet | 0 | 3rd January 2007 07:00 PM |
| Page generated in 0.11084 seconds (82.65% PHP - 17.35% MySQL) with 11 queries |
