diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Swap Meet (http://www.diyaudio.com/forums/swap-meet/)
-   -   FS:Hypex UcD180HG (http://www.diyaudio.com/forums/swap-meet/126819-fs-hypex-ucd180hg.html)
Tekko 23rd July 2008 10:06 AM
FS:Hypex UcD180HG
I bought two UcD180HG modules on ebay some time ago but never got around building an amplifier. However i dont want these anymore so therefore i sell them.
Price, well you descide by placing a bid. I have no idea what these are worth nowdays, note that they are new and never used.
Tekko 24th July 2008 09:21 AM
Noone wants these ? :bigeyes: :eek:
Flemming J P 24th July 2008 10:28 AM
Ok I'll bite, 1200 sek for both?
Tekko 24th July 2008 11:40 AM
Well new from hypex they cost alittle over 1000sek each excluding VAT and the ones i have are new never used so say 1750:- sek excl shipping and they´r yours.
Flemming J P 24th July 2008 12:36 PM
Nah that is too much. I was planing to buy the UcD180ST modules.
I think the HPR12 regulator are overpriced/overkill for use I had in mind for the amps.
Tekko 24th July 2008 12:40 PM
How about 1750sek including shipping then ?
Tekko 24th July 2008 01:19 PM
Fine 1500sek or 150 euros including shipping.
classdphile 24th July 2008 01:43 PM
New and unused sounds good! So if I were to buy these, they will come in the original sealed boxes, with the seals intact. There will also be no worn off anodizing in the threaded mount holes because they never got mounted. There will also be no wear on any of the connectors as they never saw any connections, and you can assure me of all of that? I'll write you a check today if so.
Flemming J P 24th July 2008 02:25 PM
If it doesn't work out with classdphile, I will take them for 1500 sek.
Tekko 24th July 2008 02:59 PM
New and unused as in not used as a finished amp, only tested. They are mounted to a alu thing, but that how far my build got.
However it shouldent have worn off the anodizing.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
