Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
24 Steps Volume Attenuator (Dale Resistors-Full Balanced)
Old 23rd July 2008, 06:32 AM   #1
YFW is offline YFW  United States
Account Disabled
Default 24 Steps Volume Attenuator (Dale Resistors-Full Balanced)
24 Steps Volume Attenuator 10K/100K/250K (Dale Resistors),
Full Balanced Design/Assembled
High Quality/Ulra Low Noise/Clear Sound
Ladder Type/Stereo
69.99 USD Free Shipping.
Please contact next.ps@gmail.com or visit my ebay store.
Advantage of Ladder Type Volume:
In Ladder Type Volume control, input signal only pass through two fixed resister at a time. Hence noise introduced is much reduced compared with other type of configuration such as serial type. Although serial type stepper volume is simpler to construct, input signal has to pass through many resistors, noise is thus accumulated.
Ladder Type volume control eliminate the problem of low accuracy, low stability, poor channel matching, high noise .... in traditional potentialmeter (variable resistor -VR) used in general audio equipment.
Made from :
1% High accuracy & low noise Vishay Dale RN60D metal film resistor
Perfect workmanship
7N high purity OCC copper wire
WBT audio grade high silver content solder
Other Value Available (100K, 250K or Full Balanced Type)
Old 23rd July 2008, 05:12 PM   #2
hifimaker is offline hifimaker  United States
hifimaker's Avatar
Hi, I remember seeing these in Asia a while back that come in an 8 deck version for a balance ladder attuenator. Is there a fully balanced stereo version available in 10K?
Thank you,
-David
Old 23rd July 2008, 05:20 PM   #3
Account Disabled
Yes,it's fully balanced stereo.
We have 10K/100K/250K in stock.
Old 23rd July 2008, 05:52 PM   #4
hifimaker's Avatar
This version looks like it's for balanced single ended stereo. I'm looking for a fully balanced version.
Right channel + and -
Left Channel + and -
If this version is fully balanced stereo than it's a shunt or series attuenator rather than a ladder type. A true ladder would take 8 decks, 2 per + - signal for each channel.
-David
Old 23rd July 2008, 06:03 PM   #5
Account Disabled
I know what you mean.It's truely fully balanced stereo.
You could check the photo and will found the resistors stacked by layers and the switch is also customized(re-arrangement) for this purpose.
Old 23rd July 2008, 06:05 PM   #6
Account Disabled
It's ladder Type.
Old 23rd July 2008, 06:18 PM   #7
hifimaker's Avatar
Yes, I see! I did not see the resistors cleverly stacked on top of each other. They are all there.
I'd like to buy one in 10K. I'll go to your ebay store.
Thank you,
-David
Old 23rd July 2008, 06:27 PM   #8
Account Disabled
Thanks.
It's not easy to manufacture this products and we only have limited quantiy to sell.
(And we won't manufacture this in the futur.....it's really a HARD WORK!)
Old 23rd July 2008, 07:03 PM   #9
Ted205 is offline Ted205  United Kingdom
Ted205's Avatar
hi
do you have a datasheet or list of output resistances at each step.
thanks
Old 23rd July 2008, 07:58 PM   #10
elviukai is offline elviukai
elviukai's Avatar
hi there I would take balanced version 20-100kohm 2-3pieces. how can I find yours ebay store?
natural sound reproduction from traditional dynamic drivers?!! come on.. no no, it can be.. it must be!..
24 Steps Volume Attenuator (Dale Resistors-Full Balanced)Hide this!Advertise here!
FS: Dale 23 steps Pol tomho Swap Meet 5 17th November 2006 07:27 AM
Passive balanced volume control using a single attenuator? Possible? ewildgoose Solid State 17 5th September 2004 09:58 PM
0 to -12dB Attenuator in 0,5dB steps ! Junoman Solid State 8 6th June 2003 06:58 PM
Copyright ©1999-2017 diyAudio
