| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
What I am trying to sell is a 6 channel balanced volume controller. It uses PGA2310 audio volume control IC's as well as OPA2227 input and output buffers.
The case is a durable black finish with a front panel mounted master volume and separate Ch1/2, Ch3/4, and CH5/6 gain controls. All potentiometers are Alps. The 3 gain control pots are linear RK16 and the master volume is a remote controlled log RK27 blue velvet potentiometer. The volume control project is set up to run 6 channels using my boards or can be replaced with 3 stereo Kookaburra PCBs. The same schematic as the Kookaburra was used but with 2 volume controls and a summing circuit was added to incorporate master/individual channel gain. I can not get the volume control to work so I am giving up. The multipot volume control scheme part seems to work up to the PIC microcontroller (0-5V control). After that the schematic models the Kookaburra except with 2 PGA chips from the same microcontroller. ExpressPCB was used for the board design. I have everything one might need to get this to work. I have more pictures that will help explain the design better. Please e-mail me for those. I would like to get $200 shipped/OBO for this unit. I have invested so much time it hurts to give up. |
#2 |
bump
#3 |
So, whats the problem? Why couldn't you get it to work?
#4 |
Everything up to the PIC seems fine. The PIC was programmed to be used in the Kookaburra. The code/controller is a proven design that somehow I am screwing it up.
#5 |
bump
#6 |
bump
#7 |
Any interst at $150 shipped and a modded DCX for $220 shipped?
#8 |
bump
Make me an offer if you are interested. |
#9 |
bump
#10 |
what modded in the dcx?
| DCX2496 and volume control | RogerCl | Digital Line Level | 29 | 26th September 2009 11:35 PM |
| 6-channel volume control for DCX2496 | tf1216 | Swap Meet | 4 | 17th August 2008 08:50 PM |
| DCX2496 DAC volume control PCB | bdipoala | Swap Meet | 16 | 6th April 2008 07:18 PM |
| DCX2496 Volume control | bdipoala | Swap Meet | 14 | 9th September 2007 10:57 AM |
| Least expensive 6-channel volume control for DCX2496? | mazeroth | Digital Line Level | 35 | 8th April 2006 10:46 AM |
| Page generated in 0.11707 seconds (66.80% PHP - 33.20% MySQL) with 11 queries |
