Woofers & plate amps - diyAudio
Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 7th July 2008, 12:48 AM   #1
Default Woofers & plate amps
For sale:
Two Tang Band WT-1427B 10" shallow basket neo subwoofers, 4 ohms, one has been used for testing and has a light scuff mark on the skin of its flat "cone" (actually rigid injection-molded plastic with a velvety "skin") but no solder on terminals, the other is new-in-the-box, $70 a pair plus shipping.
http://www.partsexpress.com/pdf/264-862s.pdf
Two Dayton RSS265HO-4 10" Reference HO Subwoofer drivers, 4 ohms, both new-in-the-box, $100 a pair plus shipping.
http://www.partsexpress.com/pe/pshow...TOKEN=70069138
One Dayton HPSA1000 kilowatt plate amp, 4th order variable crossover 30-200 Hz, single-band parametric EQ, line-level inputs only, lightly used with fairly high efficiency woofers (never stressed), $210 plus shipping.
http://www.partsexpress.com/pe/showd...number=300-808
One Dayton SA-240 240-watt plate amp, 4th order variable crossover 40-180 Hz. ONE OF THE LINE-LEVEL INPUTS IS BROKEN ON THIS UNIT SO YOU HAVE TO EITHER USE THE SPEAKER-LEVEL INPUTS OR MONO-SUM TO THE OTHER INPUT. Do not buy it unless you do not need TWO line-level inputs, but you can buy a y-adaptor and use the remaining one. The break is a mechanical one; the metal conductor in the terminal broke and is missing. Price reflects this limitation, so it's a great deal for the right person: $55 plus shipping.
http://www.partsexpress.com/pe/showd...number=300-804
Payment can be via Paypal or personal check. E-mail questions to:
audiokinesis at yahoo dot com
Thanks!
Duke
Old 26th July 2008, 04:31 AM   #2
The Dayton SA-240 has been sold, and for now at least the Dayton HPSA-1000 is no longer for sale.
Duke
Old 30th July 2008, 03:03 PM   #3
Bent is offline Bent  Australia
I will buy the 1000w plate amp if still for sale. Email: graeme_bentink at yahoo.com
Old 31st July 2008, 03:06 AM   #4
Dibs on the Dayton RS265s if you can give me shipping quote to 43228.
Also, if the 1000w doesn't sell I'm interested as well.
Thanks.
Old 31st July 2008, 08:00 AM   #5
Bent, I e-mailed you earlier today; good to hear from you again.
Mazeroth, looks like shipping comes to $36 via Fed Ex ground. Contact me via e-mail if that sounds okay to you; audiokinesis at yahoo dot com.
Thanks!
Duke
Old 1st August 2008, 04:41 AM   #6
Sorry for the late reply. Worked until 4 today, golf league until 7:30, went back to work and just got home 15 minutes ago (11:25 EST)! Let me check on something and I'll give you a definite answer tomorrow.
Thanks.
Old 3rd August 2008, 05:44 AM   #7
Again, sorry for replying late.
I'm trying to work on a design with these but am still not sure if they're the right driver for the project. If anyone else wants them go ahead. I'm still trying to make up my mind.
Old 3rd August 2008, 05:58 AM   #8
No problem, mazeroth.
Best of luck with your project!
Duke
Old 10th September 2008, 06:39 PM   #9
The Tang Band subwoofer drivers are still for sale, all else in this listing has been sold.
Old 11th September 2008, 01:17 PM   #10
exurbia is offline exurbia  Australia
exurbia's Avatar
Default tang band subs
No they aren't they're going in my centre channel.
Woofers and Plate amps. nodiak Swap Meet 0 2nd January 2009 03:12 AM
Help with some plate amps mazeroth Solid State 1 14th September 2008 01:31 AM
Plate amps? Enzo Solid State 6 29th January 2005 01:31 AM
Plate amps in the UK Matttcattt Multi-Way 4 5th June 2004 12:04 PM
Sub plate-amps in the UK CaRRiT Subwoofers 10 14th March 2002 06:35 PM
Copyright 1999-2017 diyAudio
