Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Want to trade: 6.2K/4 trannies for 5K/8 trannies
Old 4th June 2008, 10:20 AM   #1
mashaffer is offline mashaffer  United States
Default Want to trade: 6.2K/4 trannies for 5K/8 trannies
Would like to make a trade.
I have two OPTs from an early 60s vintage RCA console. They were used for EL84 into 4 ohm loads. I removed the amplifier a few months back at which time the output stage was working fine (I had some crackle after warm up but I would attribute that earlier circuit elements. These are hum bucking OPTs where B+ comes in not at the end but part way down the winding and the screen and preamp power is take from the end closest to the B+ tap. The primary is about 6200 or 6400 with 4 ohm load depending on whether you use just the part intended for the plate circuit or the whole primary.
Voltage ratios are
44:1 entire primary
40:1 intended primary
5.3:1 bucking section
I have no need for these trannies but I do need something of similar size with 5000 ohm primary at 8 ohm secondary. These will be used for SE 6EM7 amp. Super bass response not critical as will be used above 100Hz primarily. Something like the $18 edcors would be perfect.
Located north central IN.
mike
Old 8th June 2008, 06:34 PM   #2
Arrangements for a trade have been made.
mike
Want to trade: 6.2K/4 trannies for 5K/8 tranniesHide this!Advertise here!
little trannies looking for amp wazabee Pass Labs 10 25th January 2008 09:18 AM
vibrating trannies and hum? kmj Chip Amps 0 10th January 2006 11:03 PM
new Trannies Calvin Planars & Exotics 25 10th January 2006 08:39 PM
Paralelling trannies tade Planars & Exotics 12 26th June 2005 02:06 AM
230 V trannies in series ? Alfetta87 Solid State 5 22nd October 2003 05:05 PM
Copyright ©1999-2017 diyAudio
