| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
Here are the photos of the chassis. The left and right sides seem at a higher angle due to the perspective of the scanner. (The angle is necessary to remove the pattern from the mold, and is known as draft angle..)
Top: Tim |
#2 |
The circle in the middle (on both shots) is what's left of the sprue, where the metal is poured in. I'll try pouring in the edges (bottom) instead next time.
The two round holes are for tubes (the pattern has 5/8" holes, I filed them larger here for 3/4" 9-pin sockets), the third, oddly-shaped hole is a casting defect (mold didn't fill completely). Bottom: Tim |
#3 |
What kind of sand did you use? What binder? My furnace doesn't get hot enough on electricity, so I made a body section for propane. It's curing right now. I don't plan to spend much on specialty ingredients. I haven't even made or acquired flask frames yet. I hope my first casting looks that good. I'm dreading that it'll collapse and not be worth the while to remelt.
Dan |
#4 |
Hey, a fellow caster!
I used washed silica sand (unknown grit #) and ball clay (ideally should be bentonite, but that's all I could get; seems any clay will work). Mix and mull it until it gets sticky enough, not too moist, not too dry... The sand really needs more fine particles, that would fill in the surface real good. Flasks are simple enough, I just nailed together some 1x4s. Don't forget the alignment pins! If you want your first casting to come out good, then make sure your sand is good, and at least vent the mold a little so you know gas isn't slowing the pour. A common mistake is pouring too cold (I know it's common, I did it all the time Just remember that you won't learn anything if everything keeps going right. Make mistakes! ![]() Hmm.. obligatory disclaimer: I assume anyone interested in metalcasting understands the risks involved, and how potentially deadly five pounds of liquid metal flying through the air - propelled by as little as a single drop of water - can be. ![]() Tim |
#5 |
- Is there any interest in these? I can make them in pretty much any dimension, within about 10x10x2.5" for now. (I have a 10x10x2" pattern drying right now, after the varnish dries I'll try casting it and see if I can get it to work well.)
With a little work I should be able to make some nice heatsinks too. Tim |
#6 |
Nice work, I like that idea
What temperatures do you use to melt aluminum?
Time is the best teacher; unfortunately, it kills all its students |
#7 |
Thanks!
Melts at around 1200°F (varies a little depending on alloy), pour probably 200 or 300 degrees higher. Tim |
#8 |
I think you should offer a Pass type power amp with heatsinks to the Aleph/AlephX/X100 crowd. Monolithic, strong, inexpensive compared to the alternatives.
Petter |
#9 |
Is that within 10x10x2.5"? Tim |
#10 |
how about this one from aavid?
it's 0.38°C/W, pretty good. almost good enough for the zen v4 anyway...dunno about the other pass amps. /andrew - looking for a cheap zen v4 heatsink |
| FS: Eighteen Sound XT1086 Cast Aluminum Horns | cm7 | Swap Meet | 0 | 23rd August 2009 08:37 PM |
| WTB: Aluminum DAC chassis. | Dougie085 | Swap Meet | 0 | 19th June 2008 01:16 AM |
| Source for aluminum for chassis? | batee | Everything Else | 8 | 27th August 2004 05:18 PM |
| Anyone use a old Hayes 14.4 Aluminum chassis to build a GG? | JCoffey | Chip Amps | 7 | 26th August 2003 12:10 PM |
| Aluminum For Chassis' | vdi_nenna | Everything Else | 34 | 13th June 2002 03:37 AM |
| Page generated in 0.13096 seconds (71.71% PHP - 28.29% MySQL) with 11 queries |
