| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
#11 |
You use the sensor leg and attach the emitter resistor to that. You end up not using the emitter leg.
Donovan
Donovan ><(((º>.·´¯`·.¸¸.·´¯`·.¸><((((º>.·´¯`·.¸¸.·´¯`·.¸> <(((º>.·´¯`·.¸¸.·´¯`·.¸><((((º> |
#12 | |
I'm waiting for your response to my email on the SAP16's. Do you still want them? Please let me know. Jan Didden
/Another new issue: Linear Audio Volume 3! |
#13 |
Sorry Jan!
I did finally find a source of SAP16's in Canada and in the process of ordering some replacements. I have been away on vacation thru the weekend. Sorry about not responding sooner as I forgot about your current offer. Dan
Dan |
#14 |
Thanks for the tips.
I checked the emitter resistors and they read correctly at around 0.22R, with no darlington shortcircuits either. So luckily for me, I replaced the fuses with the correct type, and the amplifier operates perfectly. I guess it suffered some sort of thermal runaway. After checking the datasheets for these SAP15 devices i notice the maximum power dissipation rating exceeds the power deliverable by the power supply with these fuse ratings, whence the reason the trannies survived maybe btw, does anyone know what the LEDs in this CA amp are for? its an indicator? or just implemented as diodes with prefered characteristics? Cheers |
#15 |
Voltage references for current sources in the circuit.
The problem with the A5/A500 is poor heatsinking. The heatsink is just an L-angle with folded metal fins. The Cambridge amps that use LM3886 use this particular IC's "SPIKe" protection, which is on die and therefore very responsive. The SAP based circuit Cambridge used just has regular VI limiting. |
#16 |
I bought a tube of these from Profusion in the UK -- the US distributor (Arrow) would only do a minimum lot of 500 -- as I only needed to make a few amps, I will sell to anyone in the US for my cost -- $4.25/pr -- which is lower than the cost and carriage for small quantities from GB. They are on my webstore at: http://www.tech-diy.com/Store/Hexfets.htm
| LME49811 + Sanken STD03N/P | jackinnj | Chip Amps | 33 | 8th November 2011 03:08 PM |
| Sanken Output Transistors - STD03N/P - New! | zener_diode | Swap Meet | 9 | 27th September 2009 03:06 PM |
| WTB: Sanken SAP15N + SAP15P (or SAP16 - STD03) | Vil | Swap Meet | 3 | 22nd July 2009 05:10 PM |
| paralleling Sanken STD03P/N (SAP16etc.) | Sebastiaan | Solid State | 10 | 26th May 2009 12:08 AM |
| sap15n/p bias | homertooties | Solid State | 4 | 25th October 2007 06:42 AM |
| Page generated in 0.12195 seconds (57.82% PHP - 42.18% MySQL) with 10 queries |
