Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Elna Cerafine 47+47uF 500VDC wanted
Old 21st November 2007, 07:52 AM   #1
reMC is offline reMC  Netherlands
reMC's Avatar
Default Elna Cerafine 47+47uF 500VDC wanted
Hi, does anyone have or know where to get the Elna Cerafine 47+47uF 500VDC? 1000VDC is also fine!
Thanks!
Gr. Remko
Old 22nd November 2007, 07:08 PM   #2
reMC's Avatar
Default Re: Elna Cerafine 47+47uF 500VDC wanted
Thanks!
Gr. Remko
I was mistaken! I mean, off course, 100uF+100uF is also fine, I don't need 1000VDC
Old 23rd November 2007, 05:40 PM   #3
Pars is offline Pars  United States
Pars's Avatar
I'm not sure if they ever made dual 500V caps... the only ones I have seen are single (47uf/500V or 100uf/500V). Angela Instrument (http://www.angela.com) was the only place I have seen in the last two years or so that still had any of these, but they now appear to be gone.
If you look at http://www.thlaudio.com/indexE.htm, you can see what was available, but now discontinued. You are probably better off to try for some BlackGate WKZ while they are still available. I know they have 47+47uf/500V and 100 + 100uf/500V. Very expensive (~US $100 each).
Old 25th November 2007, 07:29 PM   #4
reMC's Avatar
Yeah, Angela is out now too...
Originally posted by Pars If you look at http://www.thlaudio.com/indexE.htm, you can see what was available, but now discontinued.
I already send them a e-mail, but no reply
Originally posted by Pars You are probably better off to try for some BlackGate WKZ while they are still available. I know they have 47+47uf/500V and 100 + 100uf/500V. Very expensive (~US $100 each).
Well, I don't like the BlackGate sound... Maybe I should just buy two pairs of 47uF/500VDC Elna's and make some space in my amp
Old 25th November 2007, 08:20 PM   #5
Pars's Avatar
I saw these on Ebay... better check the physical size however:
http://cgi.ebay.com/Cerafine-elna-ca...QQcmdZViewItem
Old 25th November 2007, 08:42 PM   #6
reMC's Avatar
Thanks! I saw them too tonight. But unfortunatly, I found out also tonight that the 47+47uF is the only way to go.. really go
Old 25th November 2007, 08:46 PM   #7
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Elna Cerafine 47+47uF 500VDC wanted Send a message via AIM to Peter Daniel
How about Jensens 47+47/500? They would be probably better than Elna and not as colored as BG.
http://www.partsconnexion.com/catalo.../sheet002.html
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 25th November 2007, 09:10 PM   #8
reMC's Avatar
Thank you for your suggestion Peter, but it should really be Elna...
Elna Cerafine 47+47uF 500VDC wantedHide this!Advertise here!
Wanted: 10,000uF 63V Elna Cerafine (new or used) johnm Swap Meet 0 25th July 2009 02:36 AM
12x ELNA Cerafine 10.000 uF pweber Swap Meet 0 18th December 2008 03:09 PM
Elna Cerafine Caps ocaukrell Parts 7 3rd January 2006 10:01 AM
Elna cerafine bypass?? audiocrow Parts 23 12th January 2005 02:37 AM
Elna Cerafine 16V/100uf ppereira Parts 0 24th October 2004 04:38 PM
Copyright ©1999-2017 diyAudio
