| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
Howdy,
I mostly just "lurk" on this site, especially a few years back during the pass Zen days. Not enough time or space for all the projects I want to do, so I'm selling a lot of my stuff. All stuff is sold "As is", but everything is either in use (Zen amp), unbreakable (heat sinks), or new in packages. Reasonable offers considered. Shipping from the Chicago area will be added. ---------------------------------------------------------------- Power amp : a fully working Revised Zen. Needs feet. Pictures can be seen at : http://www.passdiy.com/images/zen%20...y/zen-p3-2.jpg(front) http://www.passdiy.com/images/zen%20...y/zen-p3-1.jpg(inside) http://www.passdiy.com/images/zen%20...y/zen-p3-5.jpg(on floor, for scale) The chassis was bought thru Borbely Audio (Germany), and I believe is a "Fischer SKE 5 400 Integrated w/2xSK93", 19x16x8.5 (WxDxH, inches). Am selling the Zen because I bought an Aleph J ! The chassis is built like a tank and is plenty big enough for several of the Pass-related DIY efforts, including the F series. The chassis alone cost about $400 several years ago, and currently sells new for 410 euros ($590) plus shipping from Europe. I'll sell the whole amp for $250. Shipping will be a bit high, due to size and weight. ---------------------------------------------------------------- Circuit boards (all new in packages) : 2 Zen power amp boards 1 Bride of Zen preamp board 2 Balanced Zen line stage boards, 2 power supply boards 2 Zen V4 kits (each kit is 2 boards and all transistors for both boards) ($35 obo) Make me an offer ! ---------------------------------------------------------------- 4 Heat sinks, bought used, in great shape, but only gathering dust. 2 are 16x7x3 each (LxWxH inches), black 2 are 10x7x3 each (LxWxH inches), black All look similar to the heat sinks used by jag at http://www.passdiy.com/gallery/zen-v4-p3.htm . That's why I got them, to build Zen V4s using his layout, but I never got around to it. Bought at a flea market for $20 each; make me an offer. ---------------------------------------------------------------- Bunch of transistors and related components to build the Zen V4, all DigiKey, all new in bags. 12 IRFP044N (TO-247 style) (wanted extras just in case) 8 ZTX450 8 ZVP3310A 10 1N4004GICT (rectifiers) 15 1N4739ADICT (9.1V zeners) 8 EF1106 (10uF 100V metal poly caps) 4 PS1102J (.001uf 100V PPS cap) 10 P4773 (.0001uf 100V P cap) 4 P6946 (22000uF 50V caps) 12 P10326 (220uf 50V caps) 8 399-1806-1 (10pf 100V caps) 10 P0.47W-3BK (.47 ohm 3W 5% metal oxide res) 4 P1.0W-3BK (1 ohm 3W 5% metal oxide res) 10 47.5KXBK (47.5kohm 1/4W 1% metal film res) 5 221KXBK (221 kohm 1/4W 1% metal film res) 5 3386P-253 (25 kohm square ceramic pot) 20 1.50KXBK (1.5 kohm 1/4W 1% metal film res) 10 221XBK (221 ohm 1/4W 1% metal film res) 5 100XBK (100 ohm 1/4W 1% metal film res) 5 P100W-3BK (100 ohm 3W 5% metal oxied res) 5 6.81KXBK (6.81kohm 1/4W 1% metal film res) 5 P22W-3BK (22 ohm 3W 5% metal oxied res) Cost for the above transistors, etc. was $150, make an offer. Also, 4 Nippon Chemicon 50V, 10,000uF caps, unused (I don't know the Digikey #). ---------------------------------------------------------------- 1 unused Avel Lindberg Toroid trans, Y236852, 2x(36V@8.93A), 625VA, enough for a Zen V4. 1 unused Plitron Toroid trans, 80 VA, output = 2X60Vac, enough for a Balanced Zen line stage. 2 unused Plitron Toroid trans, 30 VA, output = 2X15Vac. ---------------------------------------------------------------- Reasonable offers considered. Please email with offers, or ask general questions here. Thanks much !
picker |
#2 |
I am interested in your Zen amp and maybe a couple HS. You have email turned off, can you email me via the forum?
Thanks!!
- Fred - |
#3 |
Please e-mail me about the heatsinks and PCB's.
Thanks, Donovan
Donovan ><(((º>.·´¯`·.¸¸.·´¯`·.¸><((((º>.·´¯`·.¸¸.·´¯`·.¸> <(((º>.·´¯`·.¸¸.·´¯`·.¸><((((º> |
#4 |
Just a quick update:
- My apologies about not having email turned on. I have all the right selections in my profile, but ... (moderator ?) - Anyway, I have (and will) emailed back to all those who respond in this thread, though, so please be patient. I've also gotten emails from others who found it thru the links above. - I will get back with more details after work today. Thanks Much, Picker
picker |
#5 | |
Am interested in both 16x7x3 heatsinks. Please send me your email.
SMathews (mathews1@earthlink.net) Quote:
#6 |
Howdy,
Thanks for all the replies and email. I appreciate your interest, and your patience. Status : The amp/chassis, heat sinks, and the 2 larger transformers have been spoken for (LanDoctor offered first), and the 2 smaller trans as well (George). So the PCBs and the Zen V4 parts remain. Any offers ? Thanks, Picker
picker |
#7 |
Removed ...
- Fred - |
#8 |
If the amp deal falls through I may be interested and could possibly pick it up. Thanks!
| OPA627AP, OPA627BP, misc stuff. | tim pattinson | Swap Meet | 33 | 13th January 2010 08:39 PM |
| FS: Misc. PCBs/Parts | Nisbeth | Swap Meet | 5 | 22nd April 2009 06:53 PM |
| spring cleaning FREE STUFF just pay shipping plus wtb/wtt ibook stuff | relientk4life06 | Swap Meet | 3 | 24th May 2006 04:32 AM |
| Misc power semiconductors | rickp | Swap Meet | 0 | 9th July 2004 12:12 AM |
| Page generated in 0.13603 seconds (84.58% PHP - 15.42% MySQL) with 10 queries |
