Maousse said:Hi Spencer,
I'm interrested in 2 kits w/o DIR9001.
Do you still have some in stock?
Thanks,
Trung
spencer said:NOS mode will be tested later.
ggta, yes still have kit but need to wait 1 week to assembly it.
Thanks.
Ok.
If it works please reserve a kit for me
Cheers
Andrea
Thanks.
Ok Spencer, thanks.
No problem to wait a little bit. Tell me when I'll have to pay and how much in PM
Hi Spancer,
Do not send it first, i may need to buy another complete set from you, when do you think you can get the complete set ready.
I need your expertise, can you help to verify the PCM63P-K2 that i post. Is that the original PCM63P-K2 chip, i saw a lot of PCM63P-K2 photo normaly the K2 printing is at the end of chip but this is different.
thanks
eddy Lim
thanks
eddy Lim
Answer to Eddy
Hi Eddy,
The "PCM63P-K2" from BB Japan that you asked about (the picture is just the same as the one which I once posted myself on a different thread here in diyAudio) must be that type which is being sold by Juang Siahaan (ptbambich@yahoo.com). I think that he has the diyAudio member name A'af (if I do remember correctly).
I just bought from him 2 different PCMs, which looks similar: The selection level on them is an integral part of the chip-name - very unusual indeed!! However they sound terrific, so I can't even imagine that they are counterfeit (fake).
According to Juang, the “PCM63K” is a military grade, while the “PCM63P-Y” is the ultimate chip. It can only looked in mastering decks of recording studio, never in consumer goods, even the HIGH END “rigs”!!
The “PCM63P-K2” which we are talking about should be very similar to the above chips.
See also:
http://java.audioasylum.com/ca/ca.jtp?ca=13007
Yours, IJ.
eddylws said:
I need your expertise, can you help to verify the PCM63P-K2 that i post. Is that the original PCM63P-K2 chip, i saw a lot of PCM63P-K2 photo normaly the K2 printing is at the end of chip but this is different. eddy Lim
Hi Eddy,
See also:
Yours, IJ.
eddylws said:Hi irgendjemand
Thanks for writing it for me, i am going to try it tonight see what is the different between the Ori PCM63P and PCM63P-K2.
After test it out will write a review on Juang Siahaan post.
thanks
eddy lim
I'm curious to know the result, too.
