Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
FS: DIR9001 to CS8412 converter board
Old 17th November 2007, 07:11 AM   #21
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
Hello Spencer,
I got my board and all of the parts. It is already assembled. Thank you, it is looking great.
Could you advise on the jumper set up please?
I am replacing CS8412 in Cal Lab Sigma II DAC. It is 16/44.1 DAC if this helps.
I know that you posted list, but it doesn't help me a lot. Is there some set up that is most likely used?
Thank you
AR2
www.burningamp.com
Old 17th November 2007, 09:16 AM   #22
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
The easiest way is to just look at your dac board. Quite likely master clock is not used so ignore J3 J4. 16 bit? That only leaves you a few permutations. Don't think J5 is important. Permanently setting to pll should work fine. Trial and error will get you there in 10 minutes And make sure the volume is not set all the way up.
Old 17th November 2007, 10:23 AM   #23
spencer is offline spencer  Singapore
Send a message via MSN to spencer FS: DIR9001 to CS8412 converter board
For most DAC, it should use 256fs, so
J3 is short
J4 is open
For output bit format, play around the J1 & J2 and there is only 4 combination of it.
Leave J5 open.
Old 18th November 2007, 06:51 AM   #24
Master Burner
AR2's Avatar
Regarding Pin assignment here is what I have:
If CD player is connected than J5 is fine if open. If sound card output is connected J5 has too be short. Otherwise it doesn't recognize format. Sound card is Sound Blaster CS2 platinum.
J1 open
J2 short
J3 short
J4 open
www.burningamp.com
Old 18th November 2007, 10:08 AM   #25
For those buyer who is not happy about the converter board, please contact me for return and I shall refund to you upon receiving your board.
Note that the board may not be compatiable with your DAC and I can only ensure it will work in my D1V2 and D1V3 DAC. It will take too much time and trouble for me to trouble shoot the special application on your DAC!
For those who really want to take the risk and try on their DAC, I shall only provide completed/tested board using my D1V3 DAC.
The board will only offer for complete unit and no more kit will be offered.
Old 19th November 2007, 07:37 PM   #26
guglielmope is offline guglielmope  Italy
Hello,
I've received the boards.
Everything is OK
Grazie
Guglielmo
Old 23rd November 2007, 04:18 PM   #27
theAnonymous1 is online now theAnonymous1  United States
theAnonymous1's Avatar
I finally finished one of my boards. It's working beautifully in an Entech 203.2 DAC with CS4329. I have jumpers J2 + J3 in place. J2 + J4 also works.
Thanks again Spencer.
Now who has some CS4390 for me.
Old 12th December 2007, 04:28 PM   #28
cadaverdog is offline cadaverdog  United States
Default I'll take two please
I am interested, but I have to ask why you would need two digital receivers. Does it have something to do with clock recovery??
I'll Paypal you when I get a confirmation email.
Old 12th December 2007, 05:37 PM   #29
analog_sa's Avatar
Default Re: I'll take two please
Just counted them again: i see only one. Have you had any drinks?
Old 12th December 2007, 06:23 PM   #30
Default UM.......................
In the schematic, there are two receivers shown. I made a mistake by thinking that they were both on the same pcb.
P.S. I've never tried alcohol; perhaps I should take it up!!
FS: DIR9001 to CS8412 converter boardHide this!Advertise here!
Pls help: DF1700 (SM5813) -> DF1704E Converter board sch. cartman Digital Source 1 22nd October 2015 05:29 PM
DIR9001 to CS8412 for sale... sklimek Swap Meet 1 5th April 2009 11:17 PM
Discrete I/V converter board cetoole Digital Source 5 21st May 2008 01:58 PM
Selling CS8414 to CS8412 converter board spencer Swap Meet 8 1st May 2007 07:08 AM
Dir9001 rehanabid Digital Source 0 26th January 2007 09:43 AM
