Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
FS: DIR9001 to CS8412 converter board
Old 31st October 2007, 11:21 AM   #11
spencer is offline spencer  Singapore
Send a message via MSN to spencer FS: DIR9001 to CS8412 converter board
Guglielmo,
Thanks for your interest.
I attach here is the 9001 converter board jumper informations for all user.
For J1 to J4, the logic is H when shorted.
Old 31st October 2007, 12:10 PM   #12
I revised the options for buyers in attached BOM3.
$6 kit without 3 ICs (DIR9001, LT11173 & 26C32)
$9 kit without 1 IC (DIR9001)
Interested please PM me.
Old 1st November 2007, 01:37 PM   #13
Some tips for soldering this SMD converter board.
0. Use 3M tape to fix the pcb on the table, cover all other pads except the 9001 pins.
1. Flux the pad before soldering but do not use excessive flux.
2. Solder the DIR9001 first.
3. Then come the 26C32.
4. Next wash the flux of 9001 and 26C32 with alcohol. Check all the pins are properly soldered or no short solder. Of course you need a magnifier glass of 3 to 5 times.
5. Solder the top 3 smd parts.
6. Go to bottom and solder the regulator LT1117 (3 pins plus the heatsink.
7. Then solder all the other smd parts on the bottom.
8. Use a empty IC socket of 28 pins DIP, insert the two 14-pin strip on the socket. Then put the pcb on top and solder all the pins. THe IC socket help for alignment and positioning of the pins.
9. You can either solder the jumper pins or use a hard wire to short the jumper.
My experience tell me that excess flux residue on the DIR9001 will stop it from functioning. 26C32 is not that critical as the pins are further apart.
If you do it carefully, all the board will have a 100% success rate. Enjoy!
Old 1st November 2007, 08:47 PM   #14
Andypairo is offline Andypairo  Italy
Andypairo's Avatar
Do you have a full kit with the DIR9001 chip?
Cheers
Andrea
I don't believe in audiophile components - except when I can get them at frugal-phile(tm) prices
Old 2nd November 2007, 01:00 AM   #15
Andrea,
If you want to get the 9001 chip from me, I shall charge $5 more using the price in Farnell Hong Kong. Lead time is one more week. Advance payment is required. Thanks.
PM me if you are interested.
Old 7th November 2007, 02:18 PM   #16
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Package arrived!
A+
Thanks again.
Old 12th November 2007, 01:40 PM   #17
Electro3000 is offline Electro3000  United States
Default Re: FS: DIR9001 to CS8412 converter board
Originally posted by spencer
This is a newly completed project for a DIR9001 to be used in CS8412 socket digital receiver DACs. The board is proven working in my D1 Ver2 clone DAC and will also be working in other DAC which accept 16 or 24 bit format as stated in DIR9001 data sheet. The only thing I want to highlight is the low 50ps jitter of DIR9001 compare to old receier 8414/8412 with >200ps jitter.
Price is US$5 with below content:
1. Two 14 pins strip.
2. 4 0.1uF smd chip cap
3. 2 10uF smd chip cap
4. 1 22uF smd chip cap
5. Some 2.5mm pins
6. One smd bead
Buyer pay shipping $1 for normal airmail and $3 for registered airmail. Paypal charge is 4%.
The rest of parts can be ordered from Farnell. Interersted please PM me.
Hi spencer,
I just sent you an e-mail. I'd like to get 3 kits.
Thank you,
Old 13th November 2007, 12:28 PM   #18
Julien,
PM sent.
Spencer
Old 13th November 2007, 02:49 PM   #19
Julien,
PM sent.
Spencer
Thanks Spencer.
I just replied to you.
I'll have 2 full kits.
Please send me the total and I'll Paypal you the funds.
Old 16th November 2007, 05:24 AM   #20
Full set of 9001 to 8412 converter board is available for $14.
Completed and tested $20.
Full kit $14.
Less DIR9001 IC will be $9.
Less DIR9001 / LT1117-5 / 26C32 will be $6.
Spencer
FS: DIR9001 to CS8412 converter boardHide this!Advertise here!
Pls help: DF1700 (SM5813) -> DF1704E Converter board sch. cartman Digital Source 1 22nd October 2015 05:29 PM
DIR9001 to CS8412 for sale... sklimek Swap Meet 1 5th April 2009 11:17 PM
Discrete I/V converter board cetoole Digital Source 5 21st May 2008 01:58 PM
Selling CS8414 to CS8412 converter board spencer Swap Meet 8 1st May 2007 07:08 AM
Dir9001 rehanabid Digital Source 0 26th January 2007 09:43 AM
