| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
Hi folks!
I have to work around size limits so that's the reason I post here instead of ordering the parts at Farnell or Digikey. The caps I would need must not exceed 20mm height and should have a capacitance between 2200uf to 4700uF @ 25VDC and are ideally 10mm snap in types. Panasonic TS-UP would be perfect, they are available as exactly these types ECOS1EP332BL or ECOS1EP472CL Unfortunatly no company I know of sells these types, only their 25mm height equivalents. If anybody could help me to get at least 2 of either it would be greatly appreciated!! Thank you very much! All the best, Hannes
fresh matched IRFP240/IRFP9240 fets || AlephJ/JX-kitsF5 transistor kits || Burning Amp BA-1/2/3 transistor kits |
#2 |
C'mon Panasonic guys! Take a second to help me with this!
Other manufacturers are of course equally welcome! I just need 2 of them! Thank you very much, Hannes
#3 |
UP! I say UP!
And I say TS-UP! To me with the parts! Hannes
#4 |
Hello
At risk of stating the obvious, have you condsidered, space permitting in laying the capacitors down on their side, or alternatively use the axial type and bend the leads around. I say this beceause the diameter is nearly always smaller than the height, and I'm sure it would be less than 20mm. Once again, sorry to waste your time if you have aready considered this. George |
#5 |
C'mon! All help greatly appreciated!
I shortly considered that, however the large cans are surrounded by other caps and I'm not that happy with that solution. Thanks a lot for your suggestion, but don't worry too much about me, it's not like I haven't any solution ;-) See I already have the alternative to use a 2200uF cap with 7.5mm lead spacing that fits into that space. However the pcb has 10mm snap-in holes, so still not a perfect match. And a tad more capacitance like 3300uF would be perfect as well. But since this is such an uncommon size, I think I will never get these caps anyway. But I can try nevertheless Thank you very much! All the best, Hannes
#6 |
wanty, wanty!
| WTS : caps 4700uf 71v | Pocoyo | Swap Meet | 4 | 29th August 2007 04:05 AM |
| Selling 2 new, unused Blackgate non-polar 2200uF 100 Volt caps | housing | Swap Meet | 5 | 10th April 2007 09:19 PM |
| FS: 2200uF/100V, 85C caps. | WALTER BURKHARD | Swap Meet | 0 | 26th March 2006 01:29 PM |
| Vishay/Roederstein 2200uF/63V 105°C caps for sale/trade | Andypairo | Swap Meet | 2 | 18th August 2004 04:09 PM |
| PSU caps, 4700uF 50v $1.50 | Stuart Easson | Swap Meet | 2 | 20th January 2003 05:22 PM |
| Page generated in 0.08794 seconds (75.06% PHP - 24.94% MySQL) with 10 queries |
