| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
I have figured out that I am never going to get around to using this. 30.00 shipped to the lower 48 (US)
Here are the specs and link. This is a Brand new, never touched kit. I opened to verify that everything was there and it has sat since then. http://eshop.diyclub.biz/product_inf...roducts_id=195 Remote control motorize volume board with 4 channel input selected by relay, on board regulate supply so only need a 9 or 12V ac power transformer (not included) Can also control the input by a rotary encoder 100K Alps or Panansonic motorized pot board size: L 120mm X W 55mm Kits include: one pcs of main pcb, IR reciver, one rotary encoder and one remote handset |
#2 |
Hey Jeff,
Ship to Canada? Toronto area. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#3 |
Hi there!
Got the Lite MV-06 volume control from ebay, from a seller called iwannebuy. New, not used, and they are selling many of them. Even though the item description says that a schematic diagram is included, they did not send one - and they said they had none when I asked for it!!!! So there are no instructions on how to connect the receiver for remote control, or how to connect the outputs for balanced or single ended operation. Anyone to send the user manual to me? salar at snafu dot de Thanks, Salar Last edited by Salar; 9th October 2009 at 07:58 AM. |
#4 |
Hello to all!
Thanks for the replies, I hope, the board will work in my Amp within the next two days. One big minus is that the main board has no holes to attach it - I had to remove the motorized volume pot and will put the board far away from the preamp section. 6 inputs, but only 4 useable for stereo mode. And that the pot ALWAYS moves to mute when you change the input is ridiciolous - or maybe a fault? The motor still tries to mute the pot even though it has reached zero, so I do not think, the motor and gear will have a long lifespan with this kind of mechanical stress. One workaround is to hit the volume button quickly after choosing the input, but very annoying. Any means to overcome this "feature" without reprogramming? All the best, Salar |
#5 |
Hi dear, i just bought the MV-02 remote control. I solder 2 x 10 ohm resistors R17, R18 in control bord and the pot stop moves to mute when i change the input. It´s ok now.
best regards hcbonfim |
#6 |
Thanks!
| Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 07:20 PM |
| Remote volume control for existing remote? | theAnonymous1 | Parts | 7 | 6th August 2007 08:22 AM |
| The remote control paratactic volume control | audio-gd | Solid State | 33 | 7th June 2007 11:16 PM |
| remote control motorised control for volume pot/knob | CharlesY | Parts | 0 | 25th July 2005 11:12 AM |
| Page generated in 0.08621 seconds (75.42% PHP - 24.58% MySQL) with 10 queries |
