| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
wanted class A amp upto 200watts per channel into 8ohms w.h.y.you can email me details of anything of interest to
paul39ish@fsmail.net |
#2 |
still looking
#3 |
now sorted thanks for the replies
#4 |
I think you cannot have any answer. Because I am working on a 20W Class A project (just 20W) and I cannot handle even its thermal problems. It needs 0.2 C/W heatsink.
I cannot imagine how much heatsink does a 200W Class A need...
Best regards, Ozgur |
#5 |
on ebay price it´s to high...
http://cgi.ebay.de/Krell-KSA-100-End...QQcmdZViewItem He say´s weght will be 70kg |
#6 |
And its just 2 x 50W as I know... Not 200W!
#7 |
How much power does the KSA160 put out in ClassA?
It might be getting close. But seriously, 200W of pushpull ClassA is some target you've set yourself. Single ended would be even worse for heat dissipation. The 100W of ClassA from the KSA100 dissipates about 270W per channel and probably runs at about 600 to 700W when ticking over. A 200W amp will probably be double this. Yes, about 1400W of quiescent consumption and the same heating power pushed into the listening room.
regards Andrew T. |
#8 |
An Englander who desires that much heat should try to locate a duo of Musical Fidelity A570 dinos.
Looks like Sponge Bob has killed another thread. |
#9 |
But what value of ClassA current can the MF570 put out?
MF usually went for high bias ClassAB in their more expensive amplifiers.
regards Andrew T. |
#10 |
The monoblock A570 can be configured to run in full Class A.
A duo weighs in at around 450lbs though.
| EL34 SE triode mode A class sch wanted | trancy | Tubes / Valves | 14 | 10th January 2008 10:16 AM |
| Class D amp wanted | ecl86 | Swap Meet | 21 | 9th August 2007 12:14 PM |
| wanted class a valve amp | brobarrie | Swap Meet | 1 | 24th July 2007 06:49 PM |
| My first class D output stage feedback wanted! | smitten | Class D | 6 | 19th April 2007 04:38 PM |
| Wanted JLH Class A Phone Amp Pcb overlay | colin.hepburn2 | Solid State | 2 | 21st February 2003 08:48 PM |
| Page generated in 0.09064 seconds (76.72% PHP - 23.28% MySQL) with 10 queries |
