Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Two 7.5 KV (!) Signal Transformer Isolation transformers, only 0, NYC
Old 11th July 2007, 07:27 AM   #1
markmaloof is offline markmaloof  United States
Default Two 7.5 KV (!) Signal Transformer Isolation transformers, only $200, NYC
Up for sale is a pair of Signal Transformer isolation transformers, model number DU-7.5. Each one weighs 100 lbs, can provide balanced power to an entire system (or run an arc welder, if you choose.) Not sure of age, probably from the early 90s, not brand new looking, but new they would cost $875 each ($1750 for two), I'll sell the pair for $200. One is complete and functioning. The other one had its bakelite terminal area on one side smashed up a bit during shipping (bad packing job), but there is continuity on all the connections, so no damage at all to the windings, can still be set up for tons of balanced power (and the other one, as mentioned, is unharmed.)
To see a photo and read specs, go here and scrawl down to page 28 <http://www.belfuse.com/Data/Uploaded...nalcatalog.pdf> Again, the ones I have are probably 15 years old and have some visible age/wear, but work just fine.
So here is a chance to get two transformers that would cost you over $1700 for only $200 (just covering my costs.) The thing is that I don't want to ship them (and it would be expensive, would have to go freight due to weight), so I prefer pick-up in NYC. Too much stuff in the apartment, and the spouse and I agree it's time to let some stuff go. I have too many projects going on as it is.
Mark
917-561-7484
Old 11th July 2007, 07:52 AM   #2
PM650 is offline PM650  United States
It's probably worth clarifying that these are 7.5 kVA units, not 7.5 kV.
Old 12th July 2007, 01:47 AM   #3
Default Whoop!
Yes, 7.5 kVA. As I said, you can power an entire system with one.
Two 7.5 KV (!) Signal Transformer Isolation transformers, only 0, NYCHide this!Advertise here!
Audio Signal Isolation Techniques - Analogue Optocouplers halojoy Solid State 26 9th November 2010 09:12 AM
Free Isolation Transformers Ric Schultz Swap Meet 3 29th November 2006 10:34 PM
Isolation transformers Bricolo Parts 36 28th June 2004 08:46 PM
need help with audio isolation transformers azira Parts 9 18th June 2004 10:44 PM
Isolation transformers Lo-z to HI-z Roadking Swap Meet 0 5th April 2004 01:05 AM
Copyright ©1999-2017 diyAudio
