Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 5th July 2007, 05:33 PM   #1
valveitude's Avatar
Default WTB: Aluminum Foil For Ribbon Build
I have sourced everything I need for this project, except the foil. I am looking for some foil 6-8 micron thick, and at least .7" wide (I can cut down wider). My ribbons will be 60" long, so after pleating, I figure I will need 72" per speaker, plus enough to roach a few..so about 50 ft I guess as a minimum.
If anybody has some they are willing to let go, or know where I can purchase less than 10lb.'s (the min the wholesalers sell), please contact me here, or via email in my profile.
Thanx,
Casey
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again.
Old 5th July 2007, 10:11 PM   #2
sqlkev is offline sqlkev  United States
I want in on some too
Old 5th July 2007, 10:34 PM   #3
Cloth Ears's Avatar
These were built using standard (heavy duty) aluminium foil laminated to 12 micron mylar film. Nothing special required...
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
Old 5th July 2007, 11:34 PM   #4
valveitude's Avatar
True..any foil will work..to a degree, BUT, the efficiency suffers terribly with the thicker foils. After modeling my options till my eyes crossed, I have decided that 8 micron is as thick as I want to go..this will give me 98 dB/W with my magnet assembly, allowing me to drive them with a small triode SE amp.
Casey
Old 6th July 2007, 12:16 AM   #5
Cloth Ears's Avatar
I understand. These are driven by a 40W A-40 (Pass) Class A, down to 500Hz crossover point. And they are not very efficient.
Have you tried contacting LineSource (see this post)? Or Paul W from this one? You've already had some posts in that thread, but may have missed this (and it's already 2 years old).
Jont.
Old 6th July 2007, 12:30 AM   #6
valveitude's Avatar
Actually, it was (is) my hope that either LineSource, or Paul W sees this post. Both members have there forum email turned off, and I have no way of contacting them.
If anybody that sees this has a way of pointing either of them at this post, it would be greatly appreciated.
Casey
Old 6th July 2007, 01:59 AM   #7
Cloth Ears's Avatar
You could always try one of those "Attn: LineSource or Paul W" threads in the Loudspeaker forum, where they are still active. And post the question there...
Good Luck...
Whew! Nice post!
Jont.
Old 6th July 2007, 02:03 AM   #8
tom1356 is offline tom1356  United States
You want to unravel a film / foil capacitor of appropriate size and use the foil.
Good Luck!
My "cult-like" following is accepting applications.
Old 6th July 2007, 02:21 AM   #9
valveitude's Avatar
Cloth Ears-
If nothing comes my way in a few days, I'll probably do just that.
tom1356-
That would be plan "B". I already have some suitable caps, but if I can avoid that particular chore, I will.
Casey
Aluminum Foil to Use for Quasi - Ribbon Tweeter StephenEC Planars & Exotics 14 31st January 2009 05:27 AM
Can aluminum foil be used as sheilding? mitchyz250f Car Audio 5 4th August 2008 05:54 PM
ribbon aluminum foil ypasco Planars & Exotics 1 9th September 2007 02:05 AM
Aluminum foil used as a transducer? Hybrid fourdoor Planars & Exotics 22 23rd March 2004 01:32 PM
Page generated in 0.09022 seconds (78.68% PHP - 21.32% MySQL) with 10 queries
