Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 26th June 2007, 02:38 AM   #1
Default WTB: Aikido PSU
Looking to purchase a suitable power supply for my aikido pre that i'm building. Seems like there's so many options it's a little overwhelming, so i'd like to have a working one first, then branch off later with my own. I also have a monica 2 dac for trade if anyone's interested.
Thanks!
Dave
Old 26th June 2007, 04:23 AM   #2
I'm thinking of using the 6s7n's, but if someone has a different supply for different tubes i would also be interested!
Dave
Old 26th June 2007, 11:53 AM   #3
Check this thread for Peter Daniel's 'generic' or 'versatile' PS board. It would get you part of the way there. The universe of topologies and variations would be reduced to a few part values. - Jeffrey Hill
WTB: F4 PCB boards
Old 26th June 2007, 02:16 PM   #4
sbrtoy is offline sbrtoy  United States
sbrtoy's Avatar
Default PS Board
I am also in the process of building an Aikido with 6SN7's, and I have a PS kit on order from Welborne labs. Their PS8 provides both high voltage and filament voltage and can provide the 300V recommended for the 6SN7's.
This is my first tube project and honestly I didn't want to fry something (or myself) so I went with this kit. I am not expert enough to create my own unfortunately
If you want to share progress just PM me, at this point I have my resistors (Kiwame and Caddock), Coupling Caps (Auricap and Obbligato), and most other parts, but haven't begun assembly yet.
My plan is for a balanced linestage with remote volume and display.
Old 27th June 2007, 12:04 AM   #5
jarthel is offline jarthel  Australia
the power supply for the aikido can be simply made using a perf board.
Old 27th June 2007, 12:42 AM   #6
Do you have an easy to build schematic that i could just go ahead and build? there are so many choices i just want to pick one and go for it. but i don't know which one would be a good cost/performance/ease of build compromise.
Thanks!
Dave
Old 27th June 2007, 03:15 AM   #7
the aikido PDF comes with a very simple PSU. just follow it and away you go
Old 27th June 2007, 06:20 AM   #8
Is there any transformers you would recommend (hammond, ect?) that i could order from digikey, and is running the heater off 6v ac really that bad?
Thanks!
Dave
Old 27th June 2007, 08:09 AM   #9
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Here is a psu
http://www.diyaudio.com/forums/showt...013#post715013
Not at all bad. I built the above psu with 6,3v ac and it is dead quiet. 6V ac is essentially the same...not worth worrying about.
Old 27th June 2007, 01:10 PM   #10
Bas,
Not meaning to hijack the thread, but in the link that shows your power supply, you provide a link to a autoformer volume control. Were you joking, or would an autoformer or TVC make a good volume control for an Aikido? Expensive yes, but desirable? This was an idea I asked about on the Moskido thread and got no response. Again, sorry I'm off topic.
-Jeffrey Hill (marsupialx)
Use 9 pin Aikido PCB kit or buy 8 pin ? Renron Tubes / Valves 6 25th November 2007 04:52 PM
JB Aikido Pre 9 pin kit Renron Swap Meet 1 20th November 2007 07:51 PM
New PSU for Aikido? cbutterworth Tubes / Valves 5 6th September 2007 01:03 AM
Aikido HiFiNutNut Swap Meet 1 24th January 2007 04:26 AM
Aikido PSU help cbutterworth Tubes / Valves 48 13th October 2006 07:54 PM
Page generated in 0.11371 seconds (76.25% PHP - 23.75% MySQL) with 11 queries
