Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 18th June 2007, 06:04 PM   #1
taloyd is offline taloyd  United States
Default FS: JBL 2226H - $150 + shipping
Hello,
Subject says it all!
Speaker is in good condition...
thanks,
-Tal
Old 22nd June 2007, 11:28 PM   #2
Default bump...
Still available, price dropped to $130 + shipping.
Factory spec sheet:
http://www.jblpro.com/pages/pub/components/2226.pdf
New:
http://www.guitarcenter.com/shop/pro...12&src=4WFRWXX
Specs:
Nominal Basket Diameter 15" / 380mm
Impedance 4 or 8 ohms
AES Continuous Pink Noise Power 600 Watts
Frequency Response 30Hz - 2.5kHz
Sensitivity (1W/1m) 97dB
Voice Coil Diameter 4" / 100mm
Max. Crossover Frequency 1.2kHz
Voice Coil Material Edgewound Aluminum Ribbon
Voice Coil Winding Depth 19.05mm
Magnet Weight 6.8 kg / 15lbs.
Recommended Enclosure Volume 85-285 Liters / 3-10(ft3)
MOUNTING INFORMATION
Overall Diameter 15.27" / 388mm
Bolt Circle Diameter 14.5625" / 370mm
Baffle Cutout Diameter 14.0" / 355mm
Overall Depth 5.5" / 137mm
Net Weight 8.7 kg. / 19.125 lbs.
THIELE-SMALL PARAMETERS
Resonant Frequency (fs) 40 Hz
Impedance (Re) 5.0 ohms
Coil Inductance (Le) 1.75mH
Mechanical Q (Qms) 5.0
Electrical Q (Qes) .33
Total Q (Qts) .31
Compliance Equivalent Vol. (Vas) 175 Liters/6.2cu. ft.
Voice Coil Overhang (Xmax) 7.6mm
Reference Efficiency 3.3%
Effective Surface Area (Sd) .088 m2
*Positive voltage to BLACK terminal gives forward cone motion*
Old 26th June 2007, 08:54 AM   #3
hi
how much would shipping be to canada (h2w1x9)
thanks
Old 26th June 2007, 03:18 PM   #4
Default FedEx Int'l Ground
Hello,
Not sure how reliable the "Quick Quote" is on the FedEx site, but they said $31 USD, which is about $33 Canadian.
thanks,
-Tal
Old 2nd July 2007, 07:08 PM   #5
Default still available... $130 +_shipping
bump!
Old 3rd September 2007, 08:19 AM   #6
Default what goes <blank> in the night
Price dropped to $120 + shipping!
Old 30th January 2008, 08:46 PM   #7
Default 2226h?
did you ever sell this speaker? Or if anyone else has any I am looking for 3. Preferably cheap, or even not working would be better and I could recone them myself.
thanks
Jeremy
Old 30th January 2008, 09:31 PM   #8
Default almost
Have a local buyer... should be gone within a few days (are schedules haven't matched up). If that falls through I'll let you know.
I only have one though...
thanks,
-tal
What makes the JBL 2226H such a popular driver? Defo Multi-Way 13 11th November 2011 03:29 PM
WTB: JBL 2226G (pair) or blown 2226H/J and 1&quot; compression drivers mikey7182 Swap Meet 1 6th March 2009 03:43 AM
JBL 2226H & 2426H cd/2370 horn combo in OB project..? JandG Multi-Way 6 1st December 2008 06:40 PM
jbl 2226h built :^) mikee12345 Multi-Way 14 24th July 2003 10:08 AM
Shipping US to Canada RobPhill33 Parts 8 3rd April 2003 07:57 PM
Page generated in 0.09462 seconds (74.29% PHP - 25.71% MySQL) with 10 queries
