Jfet IV with regulator pcb for sale
This post was lost!
I have some silver mica 2700pf for use to replace C1 and C2 in the Jfet IV board. Interested can write to me.
jfet IV stage completed!
After working on the jfet stage on and off for two weeks, it is finally completed and integrated within my DAC.
I used 2 x matched 2SK170BL as provided by Spencer for each i/v board. I set the current source at the bottom at 4mA, the higher side of the recommended range of 2mA - 4mA. I didn't experiment 2 vs 1 2sk170 for the input device as I don't have the spare time to try out the different options for the input device but, to my ears, 2 x sk170 already sounds pretty good. I bet it will be even better once the boards are fully burned-in.
Thanks Spencer for your advice you had provided when I was doing the mod project!
Moe
Yes I think you have rigth 😉 😉
But in the box with your solution I have 4 PCB.
MY box is little and if is possible to have 2 PCB I take this solution
If is not possible I take 4 pcb and I re make a box 🙂 🙂
Sorry for my poor english
Thx
Matthias
