| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
I have a used Scan Speak 25W/5565A00 4-Ohm 10" subwoofer for sale. It is in perfect working condition and good physical condition. The 25W/5565A00 can be crossed as high as 600 Hz. Here are some additional SPECS.
Technical Data: Impedance - 4 Ohm Fs - 19 Hz Sensitivity - 89dB (1W/1M) Xmax - 14mm (linear, p-p) Max. coil travel - 26mm FR - 19-600 Hz Le - 0.3 mH Sd - 330cm2 BL - 10.9 Tm Vas - 88 L Qms - 3.01 Qes - 0.61 Qts - 0.51 Outside Diameter: 255mm (10") Cutout Diameter: 228mm (8.98") Mounting Depth: 86mm (3.38") $85 shipped fees included __________________________________________________ _______________ ![]()
#2 |
Someone has provided me with the correct specs:
Impedance - 4 Ohm Fs - 23 Hz Sensitivity - 89dB (1W/1M) Xmax - 16mm (linear, p-p) Max. coil travel - 26mm FR - 19-600 Hz Le - 0.3 mH Sd - 333cm2 Vas - 180 L Qms - 2.0 Qes - 0.51 Qts - 0.41 Outside Diameter: 255mm (10") Cutout Diameter: 228mm (9") Mounting Depth: 87mm (3.42") |
#3 |
$80 Shipped And I will ship international at cost.
| FS: 2 Scan-Speak 25W/5565A00 4-Ohm 10 in | omarmipi | Swap Meet | 8 | 26th March 2009 07:58 PM |
| Subwoofer using Scan Speak 18W/8535 to mate Single FR Driver | eeyore | Subwoofers | 0 | 11th January 2009 12:34 AM |
| Scan-Speak 8565-01 10" New | Fritz | Swap Meet | 1 | 19th April 2005 05:53 AM |
| Horn+TL DIY w/Scan-Speak 10" | suiram | Multi-Way | 5 | 2nd April 2002 07:54 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 09:42 AM |
| Page generated in 0.08128 seconds (74.50% PHP - 25.50% MySQL) with 10 queries |
