Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 26th May 2007, 10:38 AM   #1
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Default Original Connoisseur BD1 motor.
I have a motor for the original Connoisseur BD1 up for grabs. This early motor is considerably different to the late 70s motor in that it has a clutch-driven brass pulley and is mounted via a square plate with soft rubber grommets. Interestingly, it has a pressed steel gantry across the bottom of the motor intended for a screw to drive onto the bottom of the motor shaft. If you have an early BD1 that needs this motor, then it is yours for the postage.
The motor was given to me by a colleague at work who is having a clear-out. I have tested it and it works, but it's a bit dusty (well, it would be, it's >30 years old). Note that this motor is completely different to the later BD1 motor with plastic pulley and rubber band mounting arrangement.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 27th May 2007, 01:44 PM   #2
leadbelly's Avatar
Can it be easily retrofit into the later TT? I have one of those, and that whole rubber band thing @#$%%^&
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 29th May 2007, 05:06 PM   #3
EC8010's Avatar
Hard to say. With sufficient time and tools anything can be fitted to anything. The most important question is whether the platter is the same - if it isn't, the pulley will be wrong.
Rega Planar 3 Motor(original model) height adjustment? GCD750 Analogue Source 40 26th November 2008 01:46 PM
Connoisseur cartridge petronius Analogue Source 3 25th January 2008 09:26 PM
how to backup original cd as the same sound quality as original cd ctrn Music 3 16th May 2006 04:21 PM
Energy Connoisseur C-9 mods Wanderer Multi-Way 0 4th June 2004 03:25 PM
Page generated in 0.06871 seconds (65.19% PHP - 34.81% MySQL) with 10 queries
