| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
As I dig through closets of parts...
1) Schlumberger 2:1 120/240V transformer. Rated at 200VA thermal. Industrial model with nice looking covered screw terminals. $40 2) 15.8V(ct) transformer (7.9-0-7.9 no load) taken from my 300VA APC UPS. Has insulated lugs on the ends, making for an easy installation. $10 3) 25.6V 2A (ct) transformer $5 4) (2x) Bravox 5 1/4" (outer dia.)4 ohm mid-woofers. Used to be installed in my DIY ribbon satellites. Foam surrounds still in good condition. $15 for the pair 5) Old Toshiba laptop power supply. 12V 1.8A (input 100V), case is fine but cracked around screw hole as I forced my way to peek inside. $4 6) IOData VGA Box II - Watch composite/s-video on your computer monitor. No need for a computer, but has pass-through for it as well. $25 7) Audiotrak/Egosys Maya ASIO soundcard - with phantom power on the mike input. RCA in/outs. Optical out. Good for soft synths and bit accurate audio. Will include MIDI daughter card. PCI. Only works with INTEL chipsets $20 8) Panasonic 19~20" TV - TV was brought back from Japan. Video inputs are getting fidgety, and picture occasionally goes dim (just feels like a loose connection). $10 9) -unconfirmed- Radio Shack 10cm woofer (unused in box) $5 *** More to come *** I'm in Toronto... pick-up is preferred. Photos are available for everything. |
#2 |
Might as well lower some prices, in my attempt to scale down...
1) Schlumberger... $25 2) 15.8V $5 3) 26.5V $4 4) Bravox $10 for the pair 5) Toshiba PS - Works fine, but not worth the effort selling I think... 6) VGA Box - deal pending... 7) Gone! 8) TV - $10 for a great picture! Just feels like a solder joint repair at the video-in connectors. Would keep it if I had the space. 9) RS 10cm - Still hunting for it. 10) Intel Pentium 4 s478 heatsinks and fan (used but good condition) Actually I have 2 heatsinks. One all aluminum, and one with a copper disc, both with fans, but only one clip bracket (works on both models) $4 for both Think I'll stick to local pick-up only. More to find!... |
| What power do I need to move vertically 20kg with 4 speakers ? | pianomambo | Everything Else | 17 | 7th February 2009 02:03 PM |
| Page generated in 0.07065 seconds (66.13% PHP - 33.87% MySQL) with 11 queries |
