WTT: LM4780 for Transformer
Hello Everyone,
I had planned to build some more parallel lm4780 amps but I have two done, and I am going to instead build a bpa400. I need a transformer for it. Would anyone be interested in trading 6 - LM4780 and 4 - LM3875 for a good sized toroid? If you are interested send me an email with what you have.
Thanks,
John
Ok, since no one has any extra transformers lying around, how about some other parts for a tube preamp I am building???
Here is what I need:
Capacitors Qty
0.047uf Orange Drops 2
0.1uf Orange Drops 4
120pf Orange Drops 2
250pf Orange Drops 2
0.047uf Tubular 2
0.1uf Tubular 4
120pf Tubular 2
250pf Tubular 2
47uf / 500v 4
50uf/25v Polarized 4
Resistors
220K 1/2 Watt 4
10K 1/2 Watt 4
270K 1/2 Watt 4
68K 1/2 Watt 4
1.5K 1/2 Watt 6
100K 1/2 Watt 6
1M 1/2 Watt 6
Connectors 1/4 Jack Chassis Mount 7
Pots 10KA Chassis Mount 2
250KA Chassis Mount 4
1MA Chassis Mount 2
Tubes 12AX7 2
8 Pin Socket Ceramic 2
Reply with what you have.
Thanks,
John
Surely someone must have a 39v, 1000va torroid lying around
Maybe but a 1000VA toroid transformer worth quite a bit (Ex: Plitrons are around 170$)
Plitron transformers
1000VA Power Transformer
Output: 2 X 38VAC @ 13.16A BUT !
I don't know the BPA400 application and I may be wrong but I have serious doubts about the 39V value you mentionned. I would double-check again if this value is the voltage present on the transformer's secondaries or the rectified voltage.
Well, good luck with your part hunt !
(digikey.com is a very good place to start parts hunt)
Well I posted the 39v 1000va figure as kind of a joke. I figured someone might have offered up something smaller. I really was looking to trade as I am low on funds, but I have quite a bit of unused parts. I might as well share some of the parts that I will never use, and finally finish up some projects.
Thanks,
John
