One pair Neoplanar 8" midranges, stainless steel faceplates, $70 OBO.
12 HFA50PA60C 50A 600V HEXFREDs $5 each or $50 for the lot
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=317001&Row=670648&Site=US
3 HexFred diode bridge boards from group buy with spade connectors, $10.
12 Elna Cerafine 25V 220uF capacitors $1 each or $10 for the lot
4 Marcon (Nuva for Audio) electrolytic, screw terminal caps, 4700uF 80V $3 each or $10 for the lot
4 Nichicon CEW (black case/gold lettered) 10,000uF/50V electrolytic, tab caps $5 each or $15 for the lot
2 Nichicon "Super Through" KG 15,000uF/63V electrolytic, tab terminal caps $15 each
2 Chipamp LM3875 PCBs, one with the single power supply, one with dual mono power supplies. 4 1500uF 50V Panasonic caps included. $20 for the whole lot.
Linkwitz Lab MT1 PCB $30
Linkwitz Lab WM1 PCB $20
Some things from Per-Anders Sjostrum http://sjostromaudio.com/_unsql/forsale/index.html
3 SST-01 Soft Start boards $10 each or $25 for all three
6 Elesta relays (as recommended for the SST-01 boards) $8 each or $40 for all 6
1 fully populated and functional QSXPS (http://sjostromaudio.com/_unsql/hifi/qsxpsr0/index.html) set for +/- 12V, plus a small toroidal transformer capable of power it to 100mA worth of supply. Good for active crossovers. $50.
Paypal, personal check (held 5 days), or money order accepted. E-mail pkpickard at lycos dot com with any questions. Thanks!
They were bought from an outfit called Aurasound NW. I actually have a response curve (although it was basically on a piece of wood, not an IEC baffle or anything.) I'll try to post the curve and pictures later today. 4 ohm, 92dB/1W, capable of very high output levels (110dB+), neodymium magnets, stainless steel faceplates, 8" tall.
Thanks for the interest - more info later.
Here is a picture I took of one of the drivers:
http://picasaweb.google.com/denise.pickard/Neoplanar/photo#5061848480032383570
I'll try to dig up the response graph tonight and post it before I head out of town - otherwise it will be Thursday before I'll be able to post it.
