My woofer is thumping (not when I want it to)
Old 13th April 2007, 03:13 PM   #1
RSBosma is offline RSBosma  United States
Default My woofer is thumping (not when I want it to)
Folks,
Newbie question here. I have a plate amp that I'm using with a 10" titanic (both from Parts Express) in a small sealed enclosure. My problem is I have a thumping noise that occurs at a very low frequency. It coincides with the output of the mains and center, meaning it only happens when there is sound coming from them. It is thumping at most about 3-5 time per second. It is erratic and definately not in the signal as it happens all the time no matter the source. Any ideas, it's driving me crazy.
Thanks,
Ryan
Old 13th April 2007, 03:19 PM   #2
Jan Dupont is offline Jan Dupont  Denmark
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Thumping at 3 to 5 times per second (3 to 5 Hz)
Seems like you maybe got a bad plate amp
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 13th April 2007, 03:38 PM   #3
there was another very recent thread that confirmed feedback through the speaker level inputs was causing the low frequency thumping.
regards Andrew T.
Old 13th April 2007, 03:40 PM   #4
Jan Dupont's Avatar
I have missed that
Interesting subject
Old 13th April 2007, 04:16 PM   #5
I'm running my input at line level. I thought it might still be a ground loop problem though, is it worth it to go buy a cheater plug?
Old 13th April 2007, 04:23 PM   #6
Is this the way a ground loop manifests itself in a sub, by making a thumping sound?
Old 13th April 2007, 04:28 PM   #7
A ground loop usually results in hum at the speaker/s.
Sometimes it's hum and buzz depending on how badly the grounding error is.
regards Andrew T.
Old 13th April 2007, 05:59 PM   #8
Andrew,
Well....that's what I thought. So, any ideas on any other possibilities. The plate amp has worked faultlessly for 3 years and is now set up in my new home theater in our new home so as far as changes go, this is the only change made since it was set up in my old house. By that I mean it was just set up exactly as it was configured before, wire for wire.
Thanks,
Ryan
Old 13th April 2007, 06:15 PM   #9
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
During the transport, a part came loose. Big power supply caps have a bad reputation to do that.
Just a thought.
/Hugo
My woofer is thumping (not when I want it to)Hide this!Advertise here!
Thumping from left speaker when volume is low dru85 Tubes / Valves 2 22nd June 2006 04:47 PM
Hafler DH-120 thumping & cracking when power on smoken_hot Solid State 11 23rd March 2006 07:24 PM
DIY system setup - muting, de-thumping, spkr protection, remotes etc ... paulspencer Everything Else 5 6th January 2005 12:29 PM
Playmaster 300W amp humming and thumping ccoutts Solid State 12 4th August 2004 12:58 PM
Preventing Thumping sound Alvinttt Solid State 5 7th August 2003 12:07 AM
Copyright ©1999-2017 diyAudio
