Lining inside active subwoofer - diyAudio
Old 16th January 2003, 10:12 PM   #1
JDeV is offline JDeV  United Kingdom
Default Lining inside active subwoofer
I opened up a Yamaha YST-SW80 active subwoofer this afternoon and noticed that the inside of the subs enclosure was lined with thick "under carpet" like material only on the bottom and left side, could it have been designed to work like this or should there be material on the inside top, right side and rear as well?
"Be carefull who's advice you buy, but be patient with those who supply it."
From Baz Luhrmann's - Everybodyís Free (To Wear Sunscreen)
Old 16th January 2003, 11:21 PM   #2
diyAudio Moderator Emeritus
roddyama's Avatar
JdeV,
I would say that this is an example of a major manufacturer doing the bare minimum to keep their cost down. Itís only going to help the speaker if they were to line all the sides, but that would raise the manufacturing cost so they would have to raise the price of the speaker.
Rodd Yamashita
Old 17th January 2003, 01:52 AM   #3
Circlotron's Avatar
Default What was that again!?
I was scanning all the post titles on the main page to see what I would read and I saw this thread, and for one fleeting moment I thought the title was "*Living* inside active subwoofer". I thought hello, someone's pushing the envelope over in kooksville!
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 17th January 2003, 12:16 PM   #4
That is not so far fetched, I personally know 2 guys that live inside a sub, .................. submarine that is
Old 17th January 2003, 01:07 PM   #5
I had exactly the same! Must be very unhealthy!
dynamat for lining inside cabs slr 5000 Multi-Way 2 15th October 2008 12:32 AM
help with design SPL box (subwoofer T\S data inside) Astro Power Subwoofers 3 11th January 2006 11:42 PM
calculating subwoofer volume when lining walls justinc Subwoofers 3 6th September 2005 12:40 AM
Seal inside of subwoofer? jaybird Subwoofers 1 9th December 2003 04:34 PM
Copyright ©1999-2017 diyAudio
