I'm new so, Hi everyone.
Im using a pair of Seas P25REXDD as drivers in my subs, and I recently made an effort to improve tightness by installing a longer port in my old cabinets. What has happened is that I got an improvement in tightness, but at the same time I had what appears to be a peak somwhere in the lower regions. I'm wondering if this peak comes from the box being more of a closed cabinet as I increased the port length and that the peak could be the resonance point the setup would have if I removed the port. Does anyone have a suggestion as to how I should proceed? I wish to keep the tightness and get rid of the peak in an easy and cheap way. |
#2 |
Greets!
Sounds like the pipe's long enough for its 1/2 WL harmonics to become audible, which will require some form of damping, lowering output a bit in the process. It may be better to revert to the original vent length and damp it as required to 'kill two birds with one stone'. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 |
Speakerholic
While I certainly can't compare with GM's knowledge, when the bass sounds loose or chuffey, I say "put a sock in it" I think he's correct in suggesting reverting to the original port and damping it.
#4 |
LOL! That was my first response, but decided it was too flippant!
#5 |
Try reverting to the original port and lining it (not blocking it) with foam. Usually need an oblong around 8mm / 3/8" thick x 3(diam) x length. |
#6 |
Okay, so what seems to be the general opinion is that I should revert to my old pipe, and increase the amount of damping I use.
Hmm.... I was thinking more along the line of putting a notch filter on it to dampen the peak. I seem to get a good frequency response except for this peak wich colours the bass range. |
#7 |
If I am not mistaken your driver has a Qts of 0.44, which in BR would need a BIG box, to avoid peaking ... and with xo above 40hz, and additional room gain ..... who knows what might happen
Question is ... how low can you push a driver like this, without loss of control |
#8 |
The more I reengage in this project the more I remember how I thought when the subs came to be in the first place. The box size is around 60l wich is optimal for this driver in a closed box application, but then after a while I added a vent just to see what happened.
Without the extra amplifier, and the added output level the problems I experience now weren't that noticeable. They are now however..... Ugh. Perhaps I should plan for a new cabinet. The ones I have now are ugly anyway.( Extremely ugly according to some.) Are the Seas drivers I have worth the effort, anyone? |
#9 |
Have you experimented enough with level and xo settings ?
What kind of subamps do you have ? Which music do you play mostly, and at which level ? What are your expectations ? What are your main speakers and amp ? Do you play analogue records or only CDs ? |
#10 |
Greets!
Don't have the specs for the P25REXDD, only the P25REX, but assuming it's fairly close it's suitable for either a MLTL or pipe horn sub if you can tolerate the size. GM
| On Off pop annoying, odd mix of system. | mikee55 | Power Supplies | 2 | 28th February 2009 01:01 AM |
| Annoying 50 hz hum | fallonp | Instruments and Amps | 8 | 29th January 2009 01:50 PM |
| 200V peak to peak @25MHz | ketan | Parts | 1 | 8th June 2008 03:21 AM |
| Pre Outs and peak-to-peak ? | CheekyMonkeyVZi | Car Audio | 7 | 12th December 2006 08:30 AM |
| Annoying subwoofer hum | Dave Bullet | Subwoofers | 17 | 28th January 2004 04:40 AM |
| Page generated in 0.11157 seconds (77.63% PHP - 22.37% MySQL) with 11 queries |
