Old 1st April 2007, 12:21 AM   #1
gychang is offline gychang  United States
Default cabinet design help for 5 1/4" subwoofer
I like to design a small subwoofer using the Tang Band W5-1138SM,
pictured here: http://www.partsexpress.com/pe/showd...number=264-831
I will be using it mainly for listening to music, classical, jazz etc. I am very interested in mating it with my Cyburg Needles here:
New needles!: Homedepot mistake
I like to have a stylish subwoofer (if possible) and details of cabinet if someone can help, thanks,
gychang
Old 1st April 2007, 05:08 AM   #2
Default check this thread ...
if size is not a major issue. DJK discribes such a sub for a five inch unit well toward the end of the thread about 18 pages in.
Acoustic wave canon
moray james
Old 1st April 2007, 09:44 AM   #3
Default Re: check this thread ...
Acoustic wave canon
Moray, thanks but can't seem to locate it.
gychang
Old 1st April 2007, 03:01 PM   #4
Theli is offline Theli  Canada
This the only mention of the W5 that I could find in that thread:
http://www.diyaudio.com/forums/showt...37#post1035637
Old 1st April 2007, 03:29 PM   #5
thanks Theli, is there a calculator for sub building cabinet software on the internet?
thanks,
gychang
Old 1st April 2007, 04:14 PM   #6
Default Page 19 I think....
djk []
Offline
Post #185
"Ok, I can't hold it in anymore. I want to build one of these things. I have an orphaned (not one of a pair) RadioShack/Optimus 4" driver that has a Fs of 85 Hz, a Qts of 0.62, and a Vas of 0.10 ft^3. It has a decent mechanical excursion limit, and a nice big magnet. Would it be suitable for a waveguide system like the one pictured in Post #7? "
Post #7 just shows a 1/4W trans line. The Sound Cannon would have about 6dB more output and less cone motion, very important where small drivers are used.
For a computer desk system it is quite easy. Use a 20" long by 3" dia pvc pipe in front of the cone. Make a little box for the drver and pipes to fit into. The box hold the driver and acts like a 90* elbow. The box would be at the back left (or right) corner of the desk. A second pipe 40" long goes across the back of the desk into a 90* elbow, and then to the front through another 20" pipe. The whole thing can be hung to the underside of the desktop with a couple of strap hangers, or you could hang it on the wall.
moray james
Old 23rd June 2007, 08:35 PM   #7
velmeran42's Avatar
I was actually thinking of making a folded TL sub out of one of those so I could have a smaller sub since I'm moving into a condo. Anybody done the calculations on Martin's sheets for that one?
Old 25th June 2007, 09:07 PM   #8
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
velmerand42,
Here is an example of a folded 27.3 L TL with the W5-1138SM.
Any larger dimensioning like CSA=2 x Sd and length will work even better as this TL has minimum CSA and length.
b
1(2)
Old 25th June 2007, 09:09 PM   #9
2(2)
Old 26th June 2007, 12:25 PM   #10
FYI,A folded 32 L TL with the W5-1138SM.
b
1(3)
DIY 18" PA subwoofer cabinet CruiSE Subwoofers 17 7th June 2009 06:28 PM
FS: Energy bass cabinet (as subwoofer) for 2 x 15" in Los Angeles taloyd Swap Meet 0 23rd April 2008 12:13 AM
8" Subwoofer cabinet schematics needed. hernanstafe Subwoofers 12 6th February 2007 03:09 AM
Newbie question re: "Proper" cabinet design Ken C Multi-Way 5 8th June 2004 07:14 PM
Audax HT170JL28 6-1/2" cabinet design? JeremyD Multi-Way 0 15th February 2004 03:06 PM
Page generated in 0.11016 seconds (77.09% PHP - 22.91% MySQL) with 11 queries
