I need an active sub filter!
Old 28th March 2007, 12:47 AM   #11
TwisterZ is offline TwisterZ  United States
Send a message via AIM to TwisterZ
I'm not sure if your looking for a project or a simple solution but here is what I used in my system, BEHRINGER CX2310 CROSSOVER, paid $64USD shipping included. It has 2 inputs & 5 outs, L&R high out, L&R low outs & a summed low pass mono sub out.
Old 28th March 2007, 08:26 AM   #12
DorinD is offline DorinD  Romania
DorinD's Avatar
Default Re: I need an active sub filter!
Originally posted by hernanstafe
... Does anyone know a working, suitable ACTIVE filter? I've been looking for one on the net for quite some time but i can't find it
PS: I remind it should also sum up both channels.
Cheers!!
Yes Hernan, I know one. Mine. If you have some hands on electronics see here:
http://www.hi-fi.ro/fhifi/download.php?id=12620
or
http://www.hi-fi.ro/fhifi/viewtopic....r=asc&start=45
my "summing/crossing@70Hz/phasecontroll" device built with discret components on air. Cheers!
Dorin
Old 28th March 2007, 05:16 PM   #13
dswiston is offline dswiston  United States
just wondering, what are those 3 opamps in the lower part of the schematic?
First one is a buffer, the second two make up the low-pass filter.
Seeing as how you are having numerous questions with this stuff, may I suggest taking it slow and working on understanding what is going on step by step. There are three or four threads with you asking similar questions, try to keep this to one thread so progress and previous question/answers can be tracked so someone isn't giving you the same answer or suggestion 4 times.
Circuits you might find anywhere on the web often leave out the power supply section, simply speficying +/- X Volts at some point on the schematic. They often leave out bypassing caps for the supply lines. These are normally understood to be needed / included. So if you ask someone "Is that all of the circuit", you'll probably get a "yes".
It sounds like you might want to find something predesigned and on a PCB with a BOM (Bill of Materials) that you can simply assemble. I'd suggest looking for this as a start, you'll more than likely have to spend some money buying the PCB/design.
Old 2nd April 2007, 05:26 PM   #14
trip-pcs is offline trip-pcs  Germany
Default active crossover
you could try this one. The circuit was designed by some members of a German hifi-forum and me as active crossover for sub/sat systems with variable crossover frequency, either with pluggable resistors or a rotary switch. Gain is variable for sub- and sat-channels.
Moreover it offers summing of both channels for subwoofers or mono use, this can be configured with a jumper.
Voltage supply is included on the printed circuit board, only standard components are used. MKP condensors should be selected to ensure tolerances of at most 5%. Such types are also available at electronics distributors.
The whole thing is quite easy to build, costs are about 30$ without enclosure.
If interested, ask for further information.
Ciao Phil
Old 2nd April 2007, 07:27 PM   #15
hernanstafe is offline hernanstafe  Argentina
trip-pcs i'm really interested in that circuit it looks nice. The only thing i'd like to know is if there are any pcb layout available. Thanks for your help btw!!
Old 2nd April 2007, 09:03 PM   #16
Hornlover is offline Hornlover  United States
Here is a great sounding crossover. Available as a bare board or kit. It includes an on board regulated power supply, which most kit types omit.
http://www.audio-kits.com/page/page/4071180.htm
Old 2nd April 2007, 11:01 PM   #17
Of course there is a pcb. I tried the circuit, it works well.
Old 2nd April 2007, 11:01 PM   #18
Unfortunately I can't upload files with high resolution here.
You get all information needed in a zip-file here:
http://www.file-upload.net/download-...eiche.zip.html
A picture of my design can be found below...
Old 4th December 2007, 09:32 PM   #19
After a long time of not working on this (because i was busy with college) i'm going to keep working on my amp/pream projects. I'm going to build trip-pcs filter, but i'd like to know if you could help me understand what you sent me since i really don't understand that language!!
Thanks in advance
I need an active sub filter!Hide this!Advertise here!
Active Filter Four help Cobra2 Solid State 9 21st April 2009 10:00 AM
active filter from rod elliot and sub filter questions wuffer Parts 0 2nd October 2005 01:12 PM
Active Filter ChevS-10 Solid State 4 24th June 2005 05:35 PM
active filter k1jroth Chip Amps 50 1st December 2004 04:15 PM
looking for active filter sim P.Lacombe Everything Else 0 2nd January 2003 09:33 PM
Copyright ©1999-2017 diyAudio
