Just a heads up. There's a new woofer coming on the market from Mach5audio called the IXL-18.4. The specs are:
Fs = 15.4Hz Re = 3.2Ohm Qms = 4.87 Qes = 0.39 Qts = 0.36 Vas = 556L Sd = 1029.2cm BL = 15.1 Mms = 228g Cms = 0.37mm SPL = 89.2 Xmax = 22mm Pricing has yet to be set, but I'm willing to bet it'll be affordable considering the other Mach 5 drivers. Personally, I can't wait to build a couple of HT subs with these!!! You can read about it here. http://www.soundsolutionsaudio.com/f...opic=7142&st=0 |
#2 |
cool - what's ~ shipping to US?
#3 |
Magneto the Gravity Man
FOAM SURROUND .....................UGH!!!!!!!!
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#4 |
Speakerholic
Ugh?
Why on earth would you say that? A lot of persons prefer the foam surround. Some last 20 years. How long are you planning to keep a woofer for? |
#5 | |
#6 |
I'm not sure what the "icky" refers to. I have a pair of Celestion Ditton 15XR speakers from 1979 that haven't missed a beat yet.
#7 |
Update. I emailed Mach5Audio about the pricing. The preorder will be a 20 dollar deposit. When the subs come in it'll be 175 U.S. which includes shipping to anywhere in North America. Sounds like a good deal to me. I'm getting 2 of them. Can't wait to install them up in my home theater!!!
#8 | |
= I'm kidding. Not a thing wrong with foam surrounds. I have 2 MJ-18, they have foam suurounds. For the money, these subs are amazing.
#9 |
wow, fits in my 200liter closed, -3db/30hz and -12db/15hz, pretty good - Fs=15hz at "only" Mms=228gr
#10 |
This woofer looks also promising for a sono-tube application. As I don’t like the normal vented variant with the driver at one end and port at the opposite, I tested a TL variant I don’t remember the design origin of. The tube was 225 cm and seems to work well for this new driver but - 10" less = 2 m even better and more optimal. Driver sag is within rec. limits and for Usd 175 it looks like a bargain. b 1(4) |
| 4 ohm or 8 ohm woofer in 2 way | mmgando | Multi-Way | 0 | 4th December 2007 07:14 AM |
| What can I do with this woofer? | Bricolo | Multi-Way | 5 | 1st April 2004 09:37 PM |
| diy sub-woofer | takashi | Subwoofers | 3 | 19th August 2003 09:16 PM |
| the best mid-woofer? | joz | Multi-Way | 4 | 19th March 2003 08:19 AM |
| Qts of Push-pull woofer and Compound Woofer System... | haggy | Multi-Way | 1 | 13th December 2001 01:30 AM |
| Page generated in 0.09421 seconds (79.65% PHP - 20.35% MySQL) with 11 queries |
