Whats the best way to measure for voltages in LT?
Old 26th March 2007, 07:28 PM   #1
mikee55 is offline mikee55  United Kingdom
mikee55's Avatar
Default Whats the best way to measure for voltages in LT?
Hi all, I've made a Linkwitz Transform, and would like to measure the ins and outs of the circuits, to check for overload.
I have taken the signal from my main amp via loudspeaker connection, droped the level using a headphone adapter from an old amp. This goes through my input mixer/ phase switch, 24db lowpass and finaly Transform. I don't have a scope but I do have A.C. millivoltmeters.
Cheers mikee55
If it don't work, I'll fix it in the mix! Or visit http://lsdp.proboards.com/index.cgi
Old 26th March 2007, 08:09 PM   #2
mikee55's Avatar
Default Here is some data
Hope this helps
Old 28th March 2007, 12:07 AM   #3
mikee55's Avatar
Default Does Nobody measure??
Old 28th March 2007, 12:20 AM   #4
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
For any meaningful measurement you need a scope, there really isn't much you can do without one..
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 28th March 2007, 01:41 AM   #5
infinia is offline infinia  United States
infinia's Avatar
Hi
What you really need is an audio signal generator to test LT functions given you have a reasonable AC millivolt meter for the task. You could also use a computer program such as the RightMark freeware to test the LT circuit.
As I see it you have added close to 19dB of gain in your signal path by inserting the LT circuit. So input levels should be adjusted downward accordingly. You don't have to shoot for 20 Hz. Try a more realistic freg giving the LT circuit 8-10dB max. remember you have room gain to boost LF as well, 20Hz is probably an unrealistic goal here.
Whats the best way to measure for voltages in LT?Hide this!Advertise here!
voltages on a zen v.9 gionag Pass Labs 5 28th May 2008 03:42 PM
Speaker Workshop - using "Measure -> Passive Components" to measure ESR ? percy Multi-Way 0 12th March 2006 09:18 PM
ESL voltages Fanuc Planars & Exotics 5 11th February 2006 07:36 PM
PSU cap voltages lawbadman Solid State 4 3rd January 2004 12:37 PM
TV set voltages? setmenu Everything Else 10 20th March 2003 01:36 AM
