diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Subwoofers (http://www.diyaudio.com/forums/subwoofers/)
-   -   Help, i dont have the power. (http://www.diyaudio.com/forums/subwoofers/98858-help-i-dont-have-power.html)
Hitecore 26th March 2007 02:57 AM
Hello,
I just built a Sonosub with a Dayton 12 in driver and Bash 300 W amp. I hooked it up today but something is wrong. It doesnt seem to be getting much power even with the volume on the amp maxed out. I can feel the sub moving. Does anyone know what I may have done wrong? Wrong enclosure size maybe?
Jeff
Cloth Ears 26th March 2007 03:05 AM
Jeff,
You're gonna have to be a bit more specific. Which Dayton 12"? Dual voice-coil? Have you tested the driver outside the subwoofer enclosure? Have you tested the amp with another driver?
Cal Weldon 26th March 2007 03:11 AM
Can you give us a little more info?
Hitecore 26th March 2007 06:27 AM
Hi guys,
I posted to soon. I found the problem. My reciever (sherwood newcastle 771) has a bad sub preout. I knew I should have gone with the NAD. Thanks.
Jeff
Cloth Ears 26th March 2007 06:32 AM
Whew, love them 'easy' fixes :)
DAMIC 26th March 2007 11:43 AM
The same happened to me recently,
http://www.diyaudio.com/forums/showt...0&pagenumber=2
If you have old cassete deck with monitor function you can cheaply amplify the signal as I did.
regards, ;)
Copyright 1999-2017 diyAudio
