Here is the place to post Tips Tricks and a vast array of knowledge about Subwoofer construction.
Please add if you see anything missing. Mikee55
If it don't work, I'll fix it in the mix! Or visit http://lsdp.proboards.com/index.cgi |
#2 |
20 x 20 x 20 inch cube, 2 inch wall (2 layers MDF), 6th order Bandpass with passive radiator.
#3 |
Nice idea Mike. I have been reading this forum for a few years now and I have to giggle sometimes at some of the construction advise offered.
I am a licensed journeyman carpenter by trade, so it's fair to say that I am a reliable source. Tools: I am spoiled, I have everything. You should have some basic hand tools such as hammer, saw , drill + common size bits, screwdrivers and clamps - big ones, as in big enough to clamp acroos the box. A jigsaw in a must( maybe you could borrow one) and if you want to get fancy, a router. Routers and router bits are expensive though and strictly speaking, you can make it without it. Screws: Save yourself some grief - don't use drywall screws. They are brittle and the head can break off while driving them. Buy the best screws you can find, usually the ones for screwing down floors are very strong. Use #8 or #10 2 inches long if you are going through 3/4 inch stock into a solid wood corner brace. Don't use too many as they may split or weaken the material you are driving them into. Do not overtighten as they may break, and always drill a pilot hole. Glue: Glue comes in a bottle, sealant comes in a tube. Modern glue makes a joint that is actually stronger than the surrounding wood. When it comes to wood, and wood products(MDF, plywood, particle board) there are only two types of glue I will use: Yellow carpenter's glue (PVA) for all interior work, and polyurethane glue for exterior or wet applications. Both of these will form the strongest, permanent bold possible. Both of these glues work best when applied liberally to the tight fitting joint and clamped till dry. The excess will squeeze out. If you find that your joints are not tight and you lack the ability to fix it, use of the polyurethane glue will actually bridge the gap, as it foams during the drying time. It can easily fill an eight inch gap( 2 MM). Just the basics. Have fun John |
#4 |
This seems a suitable thread to ask in and should be very useful overall
https://secure.wilmslow-audio.co.uk/...c096ad0a661887 My B&W speakers seem to have it wrapped around but it doesn't look like real wood anyhow. |
#5 |
Oh Joy! ... sub box makin' ... Got any pics?
(That glue tip from MJL21193 is a great help. The screws, too)
Over compression is a problem with modern CD recordings |
#6 |
Dr.EM: You should veneer one face at a time. Cut your pieces slightly larger, iron on and then CAREFULLY trim off the excess. Save the face of the box for last. Patience is key.
#7 |
Dr.Em,
My old 602's were wrapped with black ash effect vinyl. Thats probably why it goes round the corners nicely - it's not veneer! Rob. |
#8 |
FastEddy: Here's one. In the heat of battle, I soiled my drivers
#9 |
soiled my drivers ... is that like spottened your briches ??
Carefully, with the shop vac set to lowest, right? What did you end up stuffing that box with?? Or did it need any? " ... and were very liberal with internal bracing! ..." That's the hot tip from GR-Research.com as well = lots of bracing, corners, across the "flat lands" = the broad surface area between the corners. Check out his plans (pdf files on line).
#10 |
diyAudio Moderator Emeritus
I wish I had some pictures of the insides of some cabinets I saw while working at a pro audio company. They only used baltic birch plywood and were very liberal with internal bracing! I've seen some of the cabs with 2 15s take a 10 foot drop onto a stage and the damage was mainly cosmetic.
Brian |
| Beginner - Building a bass guitar cabinet | richmoore1998 | Multi-Way | 3 | 27th December 2008 02:31 PM |
| thinking about building my first cabinet | spc18 | Full Range | 1 | 10th July 2007 01:44 AM |
| Question on building a speaker cabinet | GuitarDudeSRV | Multi-Way | 1 | 10th June 2007 08:59 PM |
| Building guitar cabinet- help? | otokomae | Instruments and Amps | 8 | 20th October 2005 08:41 PM |
| Best technique to install crossover inside cabinet? | BobPM | Multi-Way | 17 | 5th September 2005 05:21 PM |
| Page generated in 0.11383 seconds (79.49% PHP - 20.51% MySQL) with 11 queries |
