Old 21st March 2007, 03:34 AM   #1
blue934 is offline blue934  Canada
Default computer subwoofer amp
hi guys, a couple of years ago i came across a small sub plate amp designed for computers. it used the line in from the computer and had high level outs w/volume for the satellites. now that i want to build a samll sub i can't find the amp anywhere. any ideas?
david
Old 21st March 2007, 03:53 AM   #2
MJL21193's Avatar
Did you look under the bed?
Old 21st March 2007, 05:14 AM   #3
Raoul is offline Raoul  United States
Nice one, MJL21193.
Are you looking for something like one of these:
http://www.partsexpress.com/pe/showd...number=300-784
http://www.partsexpress.com/pe/showd...number=300-782
http://apexjr.com/Dual25FR.html
http://apexjr.com/70watt.htm
http://apexjr.com/VegaARPHU2003.htm
Old 23rd March 2007, 03:28 PM   #4
thanks guys, MJL21193 - you are the man. it was under the bed in the spare room! i did look at those units raoul, but they do not allow satellites to be powered out if the line in jack is used. as i am coming from the computer, 1/8 line level is all i have. i found the one i was looking for at www.solen.ca. the KG-3100 is a 50 watt sub amp w/25w x 2 output w/volume control. perfect for computer systems, ipods, or mp3 players.
thanks again
david
Old 23rd March 2007, 10:56 PM   #5
Yeah, I realized that those amps might not be what you were looking for after I posted. Kudos to MJL21193 for his practical, common sense approach
Old 24th March 2007, 02:38 AM   #6
Kinnja is offline Kinnja  United States
Glad to see you found it, but these might have worked in case you hadn't.
Even has an optional remote volume control.
http://www.madisound.com/cgi-bin/ind....5704&pid=1621
http://www.madisound.com/cgi-bin/ind....5704&pid=1622
how to connect a non powered subwoofer to a stereo system without a subwoofer output JSD777 Multi-Way 4 20th September 2005 03:19 PM
Subwoofer circuit (computer) Michael Allen Subwoofers 1 24th August 2005 01:51 AM
DIY computer subwoofer & amp. GiveMeBoost Subwoofers 7 10th February 2005 01:51 PM
I need help with subwoofer deisign: HUGE inexpensive subwoofer hottyson Subwoofers 16 4th May 2004 03:51 AM
Small computer Subwoofer.. deepanger Solid State 8 19th July 2003 08:48 PM
Page generated in 0.07702 seconds (76.77% PHP - 23.23% MySQL) with 10 queries
