What size cable?
What size cable?
Old 28th March 2007, 09:02 AM   #21
Foxx510 is offline Foxx510  Australia
I seem to recall reading somewhere that wire gauge on subs has a big effect on damping factor. Not sure if there is any substance to it or not....
Old 28th March 2007, 09:06 AM   #22
all speakers that use a selected Q to tailor the low end response will be affected by extra resistance from the source+ connections.
Low end could just as easily apply to a full ranger or a mid/mass or a bass only or a mid only.
regards Andrew T.
Old 29th March 2007, 12:48 AM   #23
Cloth Ears is offline Cloth Ears  Australia
Cloth Ears's Avatar
Originally posted by OzMikeH
just make sure you put the cords in opposite directions, you don't wants the electrons twisting anticlockwise on the way back to the amplifier in the southern hemisphere.
har har har
can even use white and grey cords for polarity.
No, I've found yellow (with blue and red stripes) cords from Bunnings to be really effective. And you can use the red/blue stripes to work out that your cords are running in the right direction.
The secret is to remember which end of the cord you cut which plug off (as the electrons flow from the wall into the other end, don't they?). And the electrons (jumbo ones from big amps) flow from the negative to the positive nodes of the amp. BUT, omigod, when I connect it up in bridged mode I have to use both positive speaker binding posts! What am I to do... ?
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
Old 29th March 2007, 11:35 AM   #24
OzMikeH is offline OzMikeH  Australia
I must point out to novices here that he is joking, (I hope - because I was with the clockwise thing)
And to set the record straight the electrons go both ways. Any audio signal is alternating current. (yes, technically it can have a dc offset but this is not a good thing for a speaker)
Old 29th March 2007, 01:13 PM   #25
even our novices know that electrons go in all directions (was it Brown? or was he on about gases?) and not just when AC flows.
It's the general drift that is seen as current flow and it's the drift in alternating directions that we interpret as AC.
Just to compound it the drift in a particular direction is negative flow.
And then we go and reverse it into our conventional current flow.
Stupid us (we expect novices to learn this!!).
regards Andrew T.
Old 30th March 2007, 02:08 AM   #26
Cloth Ears's Avatar
I must apologise also. Even though this is not a DIY amplifier we are talking about, the voltages and amperages (?is that a word?) that it can generate could be uncomfortable, if not down-right dangerous.
I do not wish to contribute to the Darwin awards, even if inadvertantly.
Don't worry, Mike, I know just enought to keep knitting needles out of the sockets in the wall - and that jumbo electrons go any damn way they want to!
Jont.
Old 30th March 2007, 02:30 AM   #27
Cameron Glendin is offline Cameron Glendin  Australia
Oh dont forget the impossibility and importance of oxygen free cables!!!!!! We dont want those jumbo electrons to breath!!!!!! Its way better for them to hold there breath from the amp to the driver. Otherwise they might slow down or decide to live and build homes and then breed inside the cable!!!!!!
Old 30th March 2007, 02:33 AM   #28
Cloth Ears's Avatar
Will I need breeder resistors to stop them doing that ?
Jont.
Old 30th March 2007, 06:34 AM   #29
GM is offline GM  United States
GM's Avatar
Originally posted by Cloth Ears
FYI on this amp/subwoofer, I am expecting a total of about 6 feet of cable total. 18 inches to the first terminal, 18 inches connecting the 2 drivers (in series), 36 inches back from the second driver to the amp.
When I do 2 runs of cable, it subtracts 3 from the AWG rating, doesn't it? So, 2 runs of 16, gives 13, and 4 runs of 16 gives 10. that's right, isn't it?
Greets!
Power wire runs are all about voltage drop (Vd) over distance, so for such a short run/11 ohms/~1453 W (based on 34 dB gain) with fractional Vd you only need ~2979 CM, or 15 ga. if copper, so anything bigger is essentially wasted, though of course it doesn't hurt performance in a sub app. Anyway, the terminations are typically the weak link in high power transient situations, with cold weld (properly crimped) connections to ring tongue connectors for stud or screw mounting being preferred over typical consumer speaker connectors.
Plenty close enough.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 30th March 2007, 06:58 AM   #30
Cloth Ears's Avatar
Thanks GM.
How did you come by the figures - or is it a trade secret?
Jont.
What size cable?Hide this!Advertise here!
Anyone using microphone cable in making their phono cable? rich121 Analog Line Level 8 10th September 2010 01:50 AM
cheap cat5e cable for speaker cable fishline Full Range 6 19th May 2009 08:42 PM
New in package Component Video Cable and Toslink Cable for sale cheap jainbaby Swap Meet 1 30th December 2007 06:18 PM
problems with speaker cable as power cable pjpoes Parts 11 14th January 2007 09:24 PM
Speaker size v Room size cliffy Multi-Way 6 19th February 2005 09:34 AM
Copyright ©1999-2017 diyAudio
