I have two 10" 600w cvr dual voice coil subwoofers hooked up to a kicker 300.1 amplifier. The amplifier goes to protect when both speakers are hooked up but not when just one is. If someone could help me with this problem I would appreciate it.
some speaker specs: Nominal Impedance: 2 Ohm Power Handling Watts Peak: 600W RMS: 300W |
#2 |
How do you have them connected? Series or parallel? Series makes these two speakers 4 ohms - a good load for your amp. Parallel make 1 ohm - might be too low.
#3 |
I don't know the difference between series and parallel. I am just learning about the music stuff. Explain please...
#4 |
The load your amp is able to drive your speakers...if you have the manual or look it up. http://www.audiobahn.com/Audiobahn06/pages/tech.html explains terms pretty well check that out. In the mean time DO NOT use your amp untill you know it is hooked up right.
#5 | |
otherwise it would have been blown by now |
#6 | |
Jont. "It is impossible to build a fool proof system; because fools are so ingenious." |
#7 |
Speakerholic
Try series wiring.
Take the positive over to one of the woofers positive. Run the negative to the negative on the other woofer. Run a jumper wire from the negative on the first woofer to the positive on the other woofer. See how that has created a loop? All the power has to go through both woofers to complete the circuit. If you did it the other way ie: split the positive into two and ran one to each woofer and did the same with the negative, you have paralleled them and allowed the impedance (resistance) to drop too low. Your amp will overheat and shut down because there is not enough impedance in the system. EDIT: I see those are DVC so: You can still run them in parallel if you series them at the drivers. Are you using both voice coils? EDIT2: The amp is stable to 2 ohms so this is a suggestion: Series them at the driver. Same thing as before but this time run the positive over to one of the woofer terminals. Run a jumper from that negative, over to the positive on the other set of terminals on the same woofer. Run the negative over to the second set of terminals negative. Then you can run those two woofers in parallel (split) which is probably how you already have them. |
| What do you do to protect your car audio? | boxcustom | Car Audio | 31 | 1st June 2011 12:41 PM |
| Diodes to protect OT's.. | JandG | Tubes / Valves | 8 | 30th April 2009 06:54 AM |
| speaker protect | norstar815 | Solid State | 4 | 1st June 2008 05:40 AM |
| How do I protect tweeters? | fishdaddy58 | Multi-Way | 10 | 24th March 2008 09:48 PM |
| Protect line from 48v | impsick | Solid State | 12 | 3rd June 2007 11:28 PM |
| Page generated in 0.09898 seconds (78.60% PHP - 21.40% MySQL) with 10 queries |
