is there a site to go and not download prgm ?
Old 16th March 2007, 02:25 AM   #1
zuki is offline zuki  United States
Default is there a site to go and not download prgm ?
where parameters can be plugged in and a enclosure is recommended.
fs 20hz
qts 0.8520
qes 1.0464
qms4.5875
vas227L
efficiency 85db
sd 0.0676m
re 3.2
dual 4 ohm
Old 16th March 2007, 05:08 AM   #2
GM is offline GM  United States
GM's Avatar
http://www.kbapps.com/audio/speakerd...rs/Default.htm
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 16th March 2007, 02:59 PM   #3
thank you.
when i click the link , the work filter says.
The page cannot be displayed
Old 16th March 2007, 03:32 PM   #4
GM's Avatar
Greets!
You're welcome!
Well, then apparently you're not supposed to use your work computer for anything but work related net access because the various links works fine for me at home.
GM
Old 16th March 2007, 03:37 PM   #5
so i am not allowed to know what box will work for a driver
each time i click on a link, a page will pop up and say. copyrighted software penalties for use by companies can cost us. blah blah blah blah.
so when i try to google around the pop up, it goes to page can't be displayed
i just need enclosure size. i can handle the rest.
for example. if woofer will achieve it finest/worlds best it can do performance in a ________size box.
once i know,,,, i can build the box.
thank you
Old 16th March 2007, 04:00 PM   #6
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
It will have to be a sealed box as Qts is quite high. I will run a few different sizes through my program at the weekend.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 16th March 2007, 04:02 PM   #7
Old 16th March 2007, 04:13 PM   #8
GM's Avatar
Default Re: is there a site to go and not download prgm ?
Greets!
Apparently KBapps doesn't want other companies to use their site for potential profit.
Anyway, the driver's specs limits you to OB, sealed, or TL for best performance and 'best' is a variable depending on what you're using it for, space available, etc.. For instance, a sealed cab with a Qtc = Qts requires ~1164.435 L (~41.121634 ft^3) net, so do you have this much budget, space for such a large cab?
Even if you do, it's not going to be a high SQ alignment, so a TL makes more sense to me, but then I'm not you or live where you do, etc.. Not that it will be particularly small at ~141.6" long x ~10.56" square once folded up (~258.6461 L/9.134 ft^3 net).
GM
is there a site to go and not download prgm ?Hide this!Advertise here!
Where do I Download JBL Speakershop? kelticwizard Multi-Way 5 20th February 2010 12:14 PM
Download help 5u4 Forum Problems 5 1st November 2006 05:55 PM
c.d. or download? coils Music 23 16th April 2006 12:09 AM
neat Sony service manual download site dorkus Everything Else 0 8th December 2002 05:27 PM
