Looking at building a subwoofer with a peerless xls10 and either 1 or 2 10" peerless Passive radiators. Now i have been playing around with unixbox and i have come up with the following design based on the xls10 and 1 passive radiator. The first design i came up with was a 32l enclosure with the xls10 and 1 passive radiator. Now this should give response down to 27hz before the the passive radiator hits max excursion. I have attached a graph of this design. Now i assumed that if i could use 2 passive radiators then i should be able to come up with a design that gets me down to around 20hz, but playing with unibox i cant seem to come up with a design that will get me to that goal. Can anyone suggest a way of getting down to 20hz using the 2 passive's and the XLS10? Thanks, Greg |
#2 |
Maybe this will help. http://www.bamberglab.com/xls.shtml
Dan |
#3 |
I ran the sub you want with two passive radiators on unibox and came up with a design that will give good response down to 20Hz, but the box would be be large (70 litres). What weight PR did you input? 400 grams is what I tried. Adding weight to the PR will lower FB, but you give up some efficiency. |
#4 |
I am using 265g passive radiators. I didn't really want to go over say 50l for box size. Maybe i am being to optimistic about the response down to 20hz, maybe i should aim a little higher (although 20hz would be nice!).
#5 |
Have you thought of using the 12" PR instead?
I've found that the excursion shown in the software doesn't directly relate to the real world in most cases. I have FR drivers that should hit the stops at less than 1W but are still powering at 30W.... program material is different. There was a thread in the FR section recently about this. |
#6 |
Smaller box means adding mass to passives. This will also reduce excursion. Your 265 gram PR is more suited to a smaller driver, its too light for what you want. Its easy- add weight to the passives in unibox untill you get the response where you want it with the box size you want.
#7 |
Here's a project using the 10" XLS and passive radiator.
http://www.hardwareanalysis.com/acti...tarticle/1789/ And another using a 12" XLS and 2 passive radiators. http://www.geocities.com/adrian_mack/ |
#8 |
In Sander's project on http://www.hardwareanalysis.com/act...ntarticle/1789/
he actually adds 200 grams to the 400 gram passive radiator to get the response down to below 20Hz. Well worth reading. |
| peerless xxls sealed -vs- peerless xls with passive radiator | Naudio | Subwoofers | 8 | 23rd March 2008 09:00 PM |
| Peerless Subwoofer with Passive Radiator | GlennME | Subwoofers | 3 | 15th February 2007 09:34 AM |
| Does the Peerless XLS 12 NEED a passive radiator? | The Paulinator | Subwoofers | 27 | 6th October 2005 01:34 PM |
| Page generated in 0.09543 seconds (76.01% PHP - 23.99% MySQL) with 11 queries |
